DC voltage from SMPS external.what is that 2 pin power plug???
But Topping is a fetish product here, so it will be adored.
If you look at the Pictures it says "min" and "max", so I would say its a volume control, since the on off and the input selector are at the other site.Anyone know If it’s a volume control?
hypex nCore and Purifi amps - but u pay more for them.Not mean to be provocative but in its price point, what are the competitors?
I am interested in acquiring a small PA for a pair of passive bookshelves like JBL Stage A130.
Exactly - my speakers are around 94dB. The combination of the measured performance, dual balanced inputs and simple design is very appealing (no OLED display, tone controls, or DAC that I don’t need). Fingers crossed it arrives soon and performs well!My speakers are 98dB,
15" Woofer 8" Midrange 1.2" Dome-tweeter
I have been waiting for this kind of amp.
Thanks. With the E50, what does one do when both have volume control. ?If you look at the Pictures it says "min" and "max", so I would say its a volume control, since the on off and the input selector are at the other site.
E50 has a remote - I'd use that. So first set E50 to max volume, and set ur PA5 to maximum listenable volume, which will be below its max volume, hopefully. Then control volume via E50. That will minimize hiss (if any) and won't give u sudden very loud pops, when E50 will feed max signal to PA5.Thanks. With the E50, what does one do when both have volume control. ?
Oh come on! 1% and 10% THD figures? Hilarious. You cannot be serious.
There's like a thousand amplifier designers and engineers turning in their collective graves.
Rate you gear properly or not at all.
Excuse my ignorance and bad English.
Your opinion
Could this amplifier replace an old nad c 320 bee (at least from the specifications)?
For power and especially in quality
I wouldn't want to make it worse
Thank you very much
A real amplifier:
Here are the benefits:
Cheaper
Contains a respectable D/A converter
Similar power in real terms
Inbuilt phono stage
6 inputs
Tone controls, bass, treble and direct switch
Absolutely perfect channel balance through the entire volume range.
Motorized remote control volume, sources and muting/power.
Two individually switchable sets of speakers (A, B, A+B).
Extremely reliable and cool running amplifier topology.
Retains a good resale value.
Yes, but it takes up more space on a desk.
