It works with other opamps too. Like opa1656*5 inside opa1612's feedback loop.One day I'll have to try to build a composite unity gain buffer with a DSL line driver and feedback taken after the output isolation resistor as well. Your results are certainly outstanding.
Too expensive. Ad8397 could work but lacks protection so easy to break. Needs external protection.I was going to to something with Analog Devices chips. TI seems to be getting all the love, I think that isn't fair.
Great thanks for the reply John! Might just pick it up then would be handy for switching between headphone and speaker listeningNo issue of course.
Benefit would be a bit better SNR when playing relatively low volume. But inherent noise of 305p is rather high so I doubt there would be real benefits. But you can switch between headphones and speakers quite conveniently with L30.
These are nice but ship from China via slow airmail https://www.ghentaudio.com/part/list-rca.htmlCan someone suggest short Rca to Rca cables to connect it to D50s?
http://www.ghentaudio.com/part/a01.htmlCan someone suggest short Rca to Rca cables
Yes, the L30 should act as a preamp ie you can control the output of rca output via L30 volume.I am sorry for my question.
But I would like to know if L30 RCA output is not the same like A50?
In A50, the RCA input will automatically connect to RCA output after it is turn off which bypass the signal input to RCA output.
I am planning to use L30 as preamp to drive my power amp (Emotiva XPA2 and tube amplifier).
Thank you for the answer in advance.
From amazon US, I personally adore these, own multiple of them https://www.amazon.com/s?k=1+Foot+–+High-Definition+Audio+Interconnect+Cable+Pair+CUSTOM+MADE+By+WORLDS+BEST+CABLES&ref=nb_sb_noss
Otherwise there's also the JDS labs and Schiit rca cables. But might not be the best deal if you factor in shipping.
Thank you very much for your reply.Yes, the L30 should act as a preamp ie you can control the output of rca output via L30 volume.
noThanks for the review Amir.
I will be ordering one for sure.
Is there a projected release date for Toppings amplifier to match the E30 and L30 yet ?
AmazonBasics RCA to RCA are good. In Poland I could purchase RCA to RCA based on Klotz AC110. Maybe you could find in your local internet-stores by typing "klotz ac110 rca" in search field.Can someone suggest short Rca to Rca cables to connect it to D50s?
