Topping G5
jerm_ph
Philippines
I just stumbled upon this
Looks like a solid portable DAC/HP amp
I also found a manual. Specs is solid as expected
I wonder when will this become available
jerm_ph
jerm_ph
Philippines
Nope. ASR standard doesn't use A weight for THD+N.
I set my expectation lower for a portable dac/amp combo. I’m not expecting it to be within the top-10 of THD-N ranking list.
Still solid specs for me. Not TOTL but solid.
jerm_ph
jerm_ph
Philippines
Katji
inaudible difference. :)
Except for Golden-Ear Audiophile OCD.
Maybe there will eventually be verifiable online unsighted A/B testing, with webcam and AI bs detection. :p
Lambda
Without parametric EQ they can keep it.
it's a DAC. EQ happens in software before the DAC.
I hope some day ASR will give us a A weight number as well.
i'm okay with lots of noise below 20Hz and over 18KHz but not so okay with noise around 1-4kHz
If this ting can in fact output >6Vrms fully balanced and symmetrical in ~50Ohm load i would consider buying it.
Human Bass
Probably could based on the specs.
It only depends on convenience.
I know, but it can confuse the buyer and feels like they were lazy to not implement a real bal output when there is a connector that allows for that. Nowadays there are plenty of affordable dongles with true bal out.
Jimster480
Tampa Bay
Like what? We also don't know how much this costs... By the specs it has way more power than any dongle I've seen so....
Human Bass
For sure it has. But still leaves a "it could be even better" taste in the mouth
Matias
São Paulo, Brazil
I still wish Topping would enter the sub 200 usd dongle market.
