I just bought a G5.
So far I like it
Is there a way to use the G5 in “bypass” mode, so it will draw all its power from USB?
Or in other words, what would be the best way to use it in desktop mode to conserve the battery?
G5 is amazing. I like mine a lot too. I've been using mine a lot since I got it. Every day, maaany many hours per day.
To your question: no, unfortunately there's not a way to bypass the battery.
There is a solution though!
First a bit of background info is needed (some things might seem random - they're not, everything's important... you'll see by the end!)
So, the G5 pulls 1.35A at 5V through USB to charge its battery (as long as the charger is capable of delivering that much current)
The internal battery is 7.4V nominal, 4000mAh, which equates to approximately 30Wh. When charging at about 7 watts, the battery takes 2 hours to reach 50% from 0%, 5 hours to 100% (the top takes more time, but since the 7W charge rate is less than 25% of the 30W battery capacity, the top doesn't take much more time at all (like phones do which charge "fast" at 15W and have 15Wh battery - in their case, only the bottom 70% fills up at 15W. You reach 70% in about 40m, but it's another 40-50m until you get to 100% (and that's when the battery's new!))).
Some little known but possibly the most useful information you'll come across this month if you don't already know (almost nobody does...)
Charging from 0% to 100% causes 1.00 damage, charging from 0 to 50% causes only 0.07 damage!
(yes, that means you can charge 0 to 50% 14 times for every 0 to 100%, effectively making your battery's life SEVEN times longer!)
The way I see it, you can either: charge G5 all the way up and leave him there, and make sure he's externally powered so that he's always on. That way, whenever you start up your PC/phone/whatever, the battery doesn't get topped up over and over again. Why are you trying to avoid that? Because! Going from 94% to 100% does 50 damage!!!, 97 to 100 does 32 damage!)
(another point is 85% to 100% is 70 damage)
Personally I don't like that first option because, well.. it sucks! What I do is, when I'm at home using the thing (at PC or whatever), I charge it to 50%, then unplug the power until G5 goes dead (the power light turns red and you're at 2-3%, it turns off 15 minutes after green goes to red). Then I charge to 50% (which takes about 2h 30 to 2h 45m (depending on which mode you're in -USB/BT/nun - ask for details if you care).
Even with continual use you should get a few years out of the internal battery before G5 needs replacing (unless you're home 24/7 and an insomniac lol)
In 4-5 years, hopefully there will be new similar performing options available, and then you can relegate G5 with its dwindling battery to desk duty only!
If the world goes to crap you'll have to find a new battery for your G5.
BTW you can do this with your phone (and anything with a lithium battery - laptops, even cars!). For phones there's an app called accubattery (for android) which will chime when your phone reaches your desired max % (I suggest 64% to get the most for the least) It tracks damage from usage (1.00 is a 0% to 100% charge), and how much original capacity is remaining in your phone's battery over time.
I've used the app since 2017 and since then have never had a problem with any phone battery. One of my current phones is now 49 months old, I've charged it every day, and it still has 90% of its original capacity. At it's current rate of degradation, it'll last (used the same way) for another
5 years!!!
Side note: I recommend finding a G5 replacement battery sooner than later, and putting it away, storing it at 40%, and cycling it to 0% and back up to 40% every 8-12 months to keep it as close to new condition for as long as possible.
Long post! Lmk if you have any questions
