staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,134
- Likes
- 13,070
The E30 is solid state. There is nothing that could break in.Does the E30 need break in time in others' experience?
Then i'll see if my ears break in... finding F5 the most tolerable filter.The E30 is solid state. There is nothing that could break in.
E30 arrived yesterday via shenzhenaudio, listening now.
I'm using it via the toslink input.
The filters change the sound a bit, but all seem to have the same "edgy" quality.
I had been using a JDS atom+, which to me sounded fine right out of the box. No thinking, just plug and play, sounds great. I just needed volume control.
I'm switching them back and forth, and i'm hearing a subtle difference in subjective high frequency quality; i'm not sure if it's level, distortion, or both.
I would need a toslink switcher(...?) to do a blind test. Or get a friend to swap wires for me... Units outputting the same level. All other settings are the same.
Is it possible I got a bad unit? i know there's no way people could know of this on a forum, but is the unit not being sold anymore? did i get a knock-off unit? Have there been any reports of this?
What was the revision of your unit, the first four numbers of the serial number?My unit just died today. Getting E-d code error. Looks like, they aren't build to last at all.
2107What was the revision of your unit, the first four numbers of the serial number?
Mine does. It's attached to a laptop with sound files, also a Blu-Ray player I never use. When I shut down the computer, or disconnect the USB link, the E30 goes to idle. Start up the computer, the E30 turns on again.Does anyone know if these can be set to automatically come on with power so I don't have to find the remote every time?
@as labs To be fair, you'll hear absolutely *NO* differences in 99% of cases.
I *HAD* that setup before (my E30 died), and now I'm back to my very old Realtek ALC898 from Gigabyte's MB made in 2012 (plus the JDS Atom).
Specs here:
ALC898 - REALTEK
www.realtek.com
The differences? I can't tell, on at least 98% of cases, if I'm really picky, I could say over 90%, but that's not how it works while you listen to music... you just relax, NOT analyzed it.
Plus, I like to use Dolby Atmos, and it does boost SQ (at least perception of it).
Btw, 48kHz @ 24-bit is all we need for any type of music, and 96kHz @ 24-bit is called Studio quality now.
CD is pretty much dead now, and the new norm is indeed 48kHz/24.
If I really want to hear some differences, that means US$ 1500 (X26 for example), and I'm not willing to spend that much.
did you hear any difference between the atom and the e30?
I bought it because of the auto power on/off feature but it doesn't work for me.
It works. You need to let that feature ON.
It is On and is not working with USB on my system.
It will only turn off after N minutes of no activity from USB, or after you turn off the PC.
Also, do not use USB power from PC, to power the unit.
Like in the D10B!Well the filters are something real and absolutely needed. Giving you the ability to choose between them is pure marketing. They could have chosen one and call it a day...
