For that kind of application I'd rather be using something that comes with some RCA line inputs, for example
Tascam US-1x2HR
ESI Amber i1
Both even less expensive and based on the CS4272, which is plenty good enough for this purpose. Using 48 kHz at a minimum is advised, but I think 24/96 recording is common anyway.
PC onboard audio of the fancier kind - e.g. ALC1220/4080, ALC889, ALC897 - would also be fairly well-suited, assuming there's a line-in available at some jack (the ALC897 mic-in can only take about half a volt, not to mention the usual 2.2 kOhm input impedance is a tad on the low side).
