You mean measure the SINAD of software processing?Maybe @amirm can start reviewing the different DSP software for transparency.
And it only takes care to transport an Atmos stream to an Atmos renderer over HDMI, so no local decoding.
Probably as it clearly states 'set an Atmos device'. What's the worth then?From what i understood you have to have an Atmos capable device downstream for the HT to work.
Well it's a free app it's not like you're paying for anything.Probably as it clearly states 'set an Atmos device'. What's the worth then?
If not measurements then what do you mean "for transparency"?That was my initial thought as well, but the output from the DSP software ought to be readily comparable to the input or the expected output or such. Not measurements, though.
It is a digital signal, what will change the "resolution" unless it is intentional?I don't know exactly. But want to be sure the resolution of the source material is being preserved.
But it is also not doing what people assumed it did. It is not a decoder that decodes Atmos to multi-channel output, which is what is being discussed on this thread, it being about a multi-ch DAC.Well it's a free app it's not like you're paying for anything.
If it’s just software output one can easily check it bit for bit, no measurements needed.If not measurements then what do you mean "for transparency"?
Be assured that unless it is asked to do, software works on mathematical formulae to process the digital signal and no noise or artefacts are added.I don't know exactly. But want to be sure the resolution of the source material is being preserved without added noise, artifacts etc.
How can you if it is an active crossover, a room EQ, etc.If it’s just software output one can easily check it bit for bit, no measurements needed.
Why not? Filters are meant to add linear distortion after all. And math has rounding errors and non-infinite precision. When converting back to the target bit depth things like dither and noise shaping might add additional noise with added perceived resolution as a benefit. Not more resolution than was available in the source, but they might restore resolution lost due to the nature of the specific DSP operation (lowering gain for instance).Be assured that unless it is asked to do, software works on mathematical formulae to process the digital signal and no noise or artefacts are added.
I am obliged to mention that Mac -> USB -> multichannel DAC -> active speakers does work for atmos in apple music and tv because it is a niche (corner?) use case that matters to me. I don't make the rules.As someone who uses all 8 channels of a Okto Dac8 Pro (but would have preferred to not have waited so long), this thread is sort of a riot.
Read my post again, please. I said, unless asked to.Why not? Filters are meant to add linear distortion after all. And math has rounding errors and non-infinite precision. When converting back to the target bit depth things like dither and noise shaping might add additional noise with added perceived resolution as a benefit. Not more resolution than was available in the source, but they might restore resolution lost due to the nature of the specific DSP operation (lowering gain for instance).
DiracLive.Yeah...connect the PC with a microphone then the app will send out frequencies like what some AVR do and configures the DSP to the 8 channels. Any app on the PC that does that ?
