netcipher
- Joined
- Jan 11, 2020
- Messages
- 24
- Likes
- 21
It looks like the D90SE uses Taitien crystal oscillators.
Or I'm wrong?
Or I'm wrong?
So, the default is probably fine then?#7 is a lil' tight at 44.1, #6 would seem the better choice if you insist on a "correct" filter. I would rather avoid the slow rolloff #2 and #4 filters. My faves would probably be the "classic" fast rolloff filters #5 or #3, they may let a bit of aliasing through up to ~24 kHz but are pretty much bombproof beyond that (and the aliased 20-22 kHz range usually contains little in terms of signal anyway).
My thoughts are that you should think about it more. Break it down.Hey guys, so I just found out that my new Marantz model 30 has an "Amp direct input" - Do you think it would be better to use the D90SE's preamp instead of the Marantz preamp? - The marantz preamp does have it's own toroidal power supply and Marantz's 'magical HDAMS', but apparently it measures worse than the D90's preamp... Finding that hard to believe that the Topping would beat the full-size, separately powered, custom parts and shielded sound of the pricey Marantz.
Thoughts?
Buy Marantz SACD 30n-it will be adequately your amplifier. It isn't necessary to buy a beads and toys.Hey guys, so I just found out that my new Marantz model 30 has an "Amp direct input" - Do you think it would be better to use the D90SE's preamp instead of the Marantz preamp? - The marantz preamp does have it's own toroidal power supply and Marantz's 'magical HDAMS', but apparently it measures worse than the D90's preamp... Finding that hard to believe that the Topping would beat the full-size, separately powered, custom parts and shielded sound of the pricey Marantz.
Thoughts?
Does it do anything?Hi @JohnYang1997 , I was reading few threads from Roon Lab Community, just wonder if Topping has provided D90SE , D90MQA and D90 to Roon for testing as Roon Tested/ Roon Ready audio devices ?
https://community.roonlabs.com/t/ad...0se-to-list-of-dacs-identified-by-roon/164130
随口问问。Does it do anything?
I just wanted to know if it does anything so we can evaluate if that's doable.随口问问。
Not sure about partnership's terms and conditions, you can check out with them. As consumer, we simply expect that D90SE/D90MQA/D90 can be part of integration in network audio system even after endpoint's audio devices.I just wanted to know if it does anything so we can evaluate if that's doable.
Roon Ready isn't even possible since these DACs aren't streamers/don't have network connections. Roon Tested I believe would be the case here.Hi @JohnYang1997 , I was reading few threads from Roon Lab Community, just wonder if Topping has provided D90SE , D90MQA and D90 to Roon for testing as Roon Tested/ Roon Ready audio devices ?
I believe Roon Tested would just ensure that the DAC(s) specs are detected properly by Roon when a (Roon Ready) streaming device is plugged into it. I use a Raspberry Pi with the RoPieee (Roon Ready) OS with my D90SE and it appears that the DAC's specs are detected properly but the DAC shows up as unidentified in Roon.Does it do anything?
Exactly, to add on, Roon tested devices can be after Roon Ready endpoint or Roon Core (NUC/ROCK) via USB to Topping D90I believe Roon Tested would just ensure that the DAC(s) specs are detected properly by Roon when a (Roon Ready) streaming device is plugged into it. I use a Raspberry Pi with the RoPieee (Roon Ready) OS with my D90SE and it appears that the DAC's specs are detected properly but the DAC shows up as unidentified in Roon.
Does it help the product work with Roon currently? No, it works!Does it do anything?
Topping played a measuring game. If you are interested in the internal structure, you will see, over time they have removed a lot of high-quality components. In D90se, toroidal transformers are gone, ES9038 pro is also half the price of AK4499, no more Accusilicon oscillators, no more linear regulators from Texas Instrument, no Nichicon high quality filter capacitors, and the price remains unchanged. It's clear that it's just the measurement results and they're benefiting a lot from this website.Thank you always ASR.
Do you contend that the removed "high-quality components" adversely impacted the performance of the D90SE? If so, would be interested in your analysis.Topping played a measuring game. If you are interested in the internal structure, you will see, over time they have removed a lot of high-quality components. In D90se, toroidal transformers are gone, ES9038 pro is also half the price of AK4499, no more Accusilicon oscillators, no more linear regulators from Texas Instrument, no Nichicon high quality filter capacitors, and the price remains unchanged. It's clear that it's just the measurement results and they're benefiting a lot from this website.
