A30pro doesn't have balanced out either. It couldn't have the balanced preamp output by design.Price mainly ofcourse I'm just speculating but I bet d30pro to be quite a bit pricier than E30 (which doesn't have balanced outs)
noCan I use this thing as amplifier for my compression drivers in JBL M2?
Why not? I know people use some headphone amps on compression drivers due to the lower noise, but I don't understand what data to look at to determine what product is suitable.
You are on your own. I do not recommend.Why not? I know people use some headphone amps on compression drivers due to the lower noise, but I don't understand what data to look at to determine what product is suitable.
The drivers are 32 ohm devices, around 20 ohm if filtered with the impedance linearization and protection filter.
I'm just stupid, not full-on retarded. If you say I shouldn't I won't. Is there another Topping product you would recommend for that purpose?You are on your own. I do not recommend.
If it isn't balanced, it shouldn't be marked as such IMHO.
Well, it obviously then wouldnt sell as balanced ;-) . BTW I cant imagine a mfr like RME and others featuring "balanced" (and asking prices for balanced) where it is NO "balanced" circuitry inside.If it isn't balanced, it shouldn't be marked as such IMHO.
@amirm It is definitely the time to be testing the protection mechanisms integrated into these products (hopefully) to save attached (and expensive) headphones from accidents.
I suggest the following:
1) DC protection.
Inject an offset of x mV and wind up the volume. Monitor the output and call the level at which the amplifier triggers its onboard DC trip (or not).
2) Short circuit protection.
Wind up the level to full rated power and short the outputs. Describe the protection (or lack thereof) behaviour.
3) Overdrive/Overpower protection
Is there a level where the device enables protection based on clipping (running into the rails) or excess current consumption?
Traditional amplifiers have had these protection modes (and others) for many decades and now headphone amplifiers are getting serious in the power department, these parameters should be tested and/or commented upon.
The pass through IS balanced directly wired to the input.If it isn't balanced, it shouldn't be marked as such IMHO.
Sorry, not at the moment.I'm just stupid, not full-on retarded. If you say I shouldn't I won't. Is there another Topping product you would recommend for that purpose?
Ok so it wouldn't pass rca input from E30 to the balanced out?The pass through IS balanced directly wired to the input.
It will NOT be balanced IF is a preamp.
The FRONT headphones outputs are all single-ended.
I hope this made it clear.
No. You need A90 for that, unfortunately. But I think you can use RCA to XLR cable.Ok so it wouldn't pass rca input from E30 to the balanced out?
This is on the verge of what I would consider comfortable. Measurements is at 1M so it will need more power very quickly if you are a bit far away from it. It's not that the amp can't output that power but it may not have enough heatsinking capabilities to handle that dissipation. It may work for you and some people, but if some of those like to play loud or like play music with more bass it can be more stressing.He he. He means 'yes', just don't come crying to him when you break something.
This amp is exactly what I have been waiting decades for! I only need 2W max (115db/1w 2452SL) 16 ohm, 400hz cut off. This is not a hard drive to 100db. The A90 already handles this fine, but another 3db headroom for a crazy peak in action films (just in case) is now perfect! And yes, the background is DEAD (ear against the diaphragm) silent.
