kelesh
- Joined
- Feb 26, 2021
- Messages
- 188
- Likes
- 226
The price, however, can easily qualify as indecent.Measurements are decent. We’ve seen way worse.
” Enclosure resonances - a full metal enclosure with one piece front baffle prevents any vibrations of the cabinet around the drivers aiding in the holographic imaging.” - From Thrax website regarding the Lyra speaker.To stir the debate a bit I can give you a bit more information about the design. What is used an why. But I see very strong opinions based on observing a web picture and reading my essayIt would be good if anyone in the discussion has owned a pair or at least listened to one for a while, so a 3rd party can share experience on the actual performance. Any meaningful question will be answered.
The "break-in period" of 150+ hours serves as a break- in period for the users brain mainly. I wonder if the manufacturer can back this up by showing the different measurements at given points in time (probably newly assembled and after 1, 10 and 150 hours of use ...).” Enclosure resonances - a full metal enclosure with one piece front baffle prevents any vibrations of the cabinet around the drivers aiding in the holographic imaging.” - From Thrax website regarding the Lyra speaker.
I’d like to know why. I think they look great. I’m just curious as to why they used aluminum? I know from MTB, BMX, and even MX that aluminum is not forgiving. They actually have a 150 hour break-in per the maker? WTF is going to change in that time? That screams SNAKE OIL. He can't be serious?
"Artaski recommended about 150 hours of break-in period and said they would further improve as more time was logged in."
Aluminium is way harder than wood (MDF), especially the alloys as used in the machine construction and aerospace. Some of the advantages are that resonance moves up in frequency and is easier to damp, it also provides a stable platform for the driver, meaning it does not bend and try to deform the driver basket and the screws don't loosen up with time. (video showing how difficult it is to hold a screw tight with present vibration” Enclosure resonances - a full metal enclosure with one piece front baffle prevents any vibrations of the cabinet around the drivers aiding in the holographic imaging.” - From Thrax website regarding the Lyra speaker.
Simple, take any cone driver and measure its main resonance at different amplitudes (signal level) and you will see it is different. Play it for some time at high amplitude and measure again and you will see different readings. After some rest it might go back. Go figure why they do that but they do.The "break-in period" of 150+ hours serves as a break- in period for the users brain mainly. I wonder if the manufacturer can back this up by showing the different measurements at given points in time (probably newly assembled and after 1, 10 and 150 hours of use ...).
That has nothing to do with the break-in, which the manufacturer refers to. It is basic knowledge, that a speakers voice coil and motor have to cool down to room temperature after being pushed to high amplitude to measure the TSP properly. Even different room temperature can have a measurable effect on measurements (note the measurements of the Neumann KH 80 by Amir). The elastic components of a speaker reach their stable condition long before 150 hours of use. If the manufacturer can prove his claim by presenting differences between the measurements of one of his speakers played for an hour and for 150 hours after a proper cooling down, I would be very surprised.....Simple, take any cone driver and measure its main resonance at different amplitudes (signal level) and you will see it is different. Play it for some time at high amplitude and measure again and you will see different readings. After some rest it might go back. Go figure why they do that but they do.
It has nothing to do with temperature, you can measure the difference next day and indoors so no change in humidityThat has nothing to do with the break-in, which the manufacturer refers to. It is basic knowledge, that a speakers voice coil and motor have to cool down to room temperature after being pushed to high amplitude to measure the TSP properly. Even different room temperature can have a measurable effect on measurements (note the measurements of the Neumann KH 80 by Amir). The elastic components of a speaker reach their stable condition long before 150 hours of use. If the manufacturer can prove his claim by presenting differences between the measurements of one of his speakers played for an hour and for 150 hours after a proper cooling down, I would be very surprised.....
It has nothing to do with temperature, you can measure the difference next day and indoors so no change in humidityAs to the 150hrs it is arbitrary as some plastics take even longer.
Aluminium is way harder than wood (MDF), especially the alloys as used in the machine construction and aerospace. Some of the advantages are that resonance moves up in frequency and is easier to damp, it also provides a stable platform for the driver, meaning it does not bend and try to deform the driver basket and the screws don't loosen up with time. (video showing how difficult it is to hold a screw tight with present vibration) Any relative movement of the driver and front panel will be detrimental. Any frivolous movement of in the front baffle will also be detrimental. One pice construction resolves the issue with separate parts of the front vibrating separately and storing energy. In our case the whole structure is damped and quite rigid. Another reason is the endurance and stability of anodised aluminium in different environments as example Singapore or Hong Kong versus Colorado or Arizona. Screws hold better in allumnium and it allows for thiner walls than MDF would reducing the size of the product. Generally aluminium is way more expensive and difficult to work (heavier and costlier machinery and tools) , so few go that path or use only reinforced front panels but the precision of the workpieces is unmatched.
As to burn in time, think of it as new shoes. Some fit perfect and are comfortable immediately but some need to be worn a bit to get there. They don't change size or shape during that period so there is not much to measure. Here the effect is similar and is due to the processing of the materials that go in the speaker. Glue, membrane, voice coil and others. It is kind of a hysteresis effect that once the speaker has repeated a certain number of movements and exited its resonances soften certain bonds and the movements are less jittery and smoother while others get harder and locked in. It is noticeable in low levels and clarity. Same effect is observed on many machines and cars. I am certain all of you have experienced the effect in everyday items you use, speakers are no different.
I kind of agree, I see no mention of the enclosures made of milled aluminium, this is a big plus, I think only Magico and a Swiss company are the only other companies making metal enclosures, except for Genelec who offer it only their mini speakers.These speakers are very expensive, do not measure especially well and have some exaggerated marketing. That's a reason to not buy them, but the pile on makes me uncomfortable.
The large KEF Muon has also an aluminium enclosure and am sure also other brands/models exist, it should be said though that the advantage of such choice is more in the looks and marketing than in audibility if a conventional enclosure is well engineered.I kind of agree, I see no mention of the enclosures made of milled aluminium, this is a big plus, I think only Magico and a Swiss company are the only other companies making metal enclosures, except for Genelec who offer it only their mini speakers.
I sort of agree, but your example is of monstrous dimension and price. Metal enclosure is a good thing for several reasons. I have an aversion to what you call conventional enclosures made of cheap particle boards with Ferrari type paint job which account for a large portion of the price: Very fragile and makes no sense. It's like putting lipstick on a pig.The large KEF Muon has also an aluminium enclosure and am sure also other brands/models exist, it should be said though that the advantage of such choice is more in the looks and marketing than in audibility if a conventional enclosure is well engineered.
Source of photo: https://international.kef.com/products/muon
As an engineer I see it totally different, namely a reasonable choice is one that fulfils the predefined requirements (like vibration control, lifespan, design/looks) with minimal waste of resources (like costs, material, time, energy etc). and a good quality high density particle board with the appropriate bracing and damping is working absolutely fine for home loudspeakers which are typically transported only once in special packaging to their indoor final destination and stay there for the rest of their lifes, using unnessary expensive materials for such rather makes no sense.I sort of agree, but your example is of monstrous dimension and price. Metal enclosure is a good thing for several reasons. I have an aversion to what you call conventional enclosures made of cheap particle boards with Ferrari type paint job which account for a large portion of the price: Very fragile and makes no sense. It's like putting lipstick on a pig.
Rockport also using alu but not visible at the end result (that's the insides) :The large KEF Muon has also an aluminium enclosure and am sure also other brands/models exist, it should be said though that the advantage of such choice is more in the looks and marketing than in audibility if a conventional enclosure is well engineered.
I Agree with the technical and scientific aspect of your statement but for the rest, people do move from state to state for career and job (specifically Californians of late). I was interested in buying Wilson Shashas, not a great speaker but not a bad speaker either) and retracted because of irreparable dings and nicks. So I reiterate "Expensive lipstick on a pig".As an engineer I see it totally different, namely a reasonable choice is one that fulfils the predefined requirements (like vibration control, lifespan, design/looks) with minimal waste of resources (like costs, material, time, energy etc). and a good quality high density particle board with the appropriate bracing and damping is working absolutely fine for home loudspeakers which are typically transported only once in special packaging to their indoor final destination and stay there for the rest of their lifes, using unnessary expensive materials for such rather makes no sense.
I would say not being capable to re-use the factory packaging or call have/call people who know how to transport stuff without breaking it (especially for expensive loudspeakers like Wilsons) doesn't make a product a "pig", but rather... Also on metal enclosures irreparable dings and nicks can occur if not transported with care.I Agree with the technical and scientific aspect of your statement but for the rest, people do move from state to state for career and job (specifically Californians of late). I was interested in buying Wilson Shashas, not a great speaker but not a bad speaker either) and retracted because of irreparable dings and nicks. So I reiterate "Expensive lipstick on a pig".
But these Wilson Sasha are the opposite of your complaint, made from X-Material, not cheap particle board. Do you really think aluminum is durable to damage? It's very soft.I Agree with the technical and scientific aspect of your statement but for the rest, people do move from state to state for career and job (specifically Californians of late). I was interested in buying Wilson Shashas, not a great speaker but not a bad speaker either) and retracted because of irreparable dings and nicks. So I reiterate "Expensive lipstick on a pig".
