Robhimself
- Joined
- Jan 5, 2024
- Messages
- 17
- Likes
- 10
- Thread Starter
- #21
hehe yes, I have tried all 12 ports on my computer. 8 in the back - 2.0 and 3.0, and 4 in the front.Do you have the USB plugged into your motherboard rear panel? Have you tried using a USB port from your front panel (usually located at the front of the computer near the on/off switch)?
Edit. Just read your previous post. Try optical if you have it. It should not hum if your computer is the cause.
Edit 2. Oops, just checked and Asgard doesn't have opti out.
Even with a powered USB hub that was also connected to every port I have.
It's all windows driver compatibility... Since every port works out of the box when I boot into Linux.
And I've followed all guides that try to fix usb issues. About 80% of them tells you to update windows and update/reinstall usb drivers.
I've gotten to the point where I don't want to try jumping all the hoops anymore, out of spite towards windows.
And also why I want more than 1 option for digital input
