Desktop setup recommendations under $3000
Greetings all,
not sure how i found this place, but I'm so happy I did.
I do all my media consumption at my desk between my MAC and PC.
My current listening devices no longer inspire. I would like to upgrade my headphones and eventually get desktop speakers. (i don't have any speakers)
I have a budget of $1500 to get a DAC/AMP/Headphones and speakers. My brain hurts from youtube and totally got stunned locked. Could you guys help me level set a upgrade path?
Can I use the Eversolo Dac-z8 as my starting point to better audio? is this overkill?
Desktop
Samsung G9
Mac book Pro
Airpod Max headphones
Homepod Dual
PC win 11
Steelseries Artis nova pro wireless w/dac
PC38x
Schitt Hel 2
sennheiser momentum 4
What @staticV3 said!
Depending on the features you need, perhaps set aside $300-400 for the electronics.
You need to decide on the relative priority between headphones and speakers: 50:50 or will you use headphones more?
I don't know enough about headphones to advise (others do) but I would have thought that $500 would get you a cracking pair.
Take a look at something like Kali LP6 speakers (active, with built-in amps) as a baseline financially and aesthetically ... see what you think
I always suggest putting together a system from the speakers/headphones back. The speakers or phones will make the most difference.
You can get something from SMSL which will handle the DAC, phone amp fine. Maybe even something that is amp too, but maybe for a desktop setup some active powered monitors are the ticket. So then DAC/phone amp and active speakers. Leaving only the phones to decide. $1500 will be plenty I think.
You need to decide on the relative priority between headphones and speakers: 50:50 or will you use headphones more? 70/30 headphones to speakers
Kali is a new brand to me. Thank you
Budget update: $3000
Headphones
Aune SR 7000
Sennheiser HD 490 PRO
Arya Organic
Noire X
Speakers
Adam A4V - the tech is sublime!
Headphones
Sennheiser HD 490 PRO (These seem the most the comfortable in the 300-500 category) I wear headphones 12+hours daily
Speakers
Q Acoustics 3010c or 3020 (not sure about the dimensions) looks modern and cool
thoughts??
Q Acoustics speakers are really long on the 'depth' dimension (and rear ported), so if your desk is against a wall this may cause issues, and yep you'll need an amp to drive these too... If you don't have an amp already, I'd also say active speakers are the way to go (there's also a few technical benefits over passive speakers), look at Kali/JBL/Adam or if you want to spend more: Neumann or Genelec.
Old Sound Blaster G6 is what you need. Consider be centric towards speakers regarding budget. What do you want from headphones other than to be comfortable for prolonged period?
seems I'm missing the point of powered speakers. I need to educate myself more.
Basically; the good active speakers have seperate amps for the tweeters and the woofers in each speaker, as well as 'active crossovers' so the way they handle and distribute power is better, but I'd say the main benefit for a desktop setup is that there's going to be at least one less box on your desk (amp).
Cliched car analogy: Carburetor (passive) vs fuel injection (active).
Both achieve combustion, but fuel injection does so more effectively.
An external Amp and passive speaker system means inevitable trade-offs in accuracy and efficiency.
Active speaker systems with DSP crossover and a dedicated Amp for each driver are just better.
12+hours daily
That's a lot of hours for headphones. Maybe prioritize them more. Get cheap speakers and a better set of headphones.
For $500 speakers you won't find much better than
*Philharmonic Audio True Mini $380
*Fosi DS2 DAC $40
*Fosi V3 Amp $80
Then consider Noire X headphones for $1k? Might be too heavy for all day...
I think have some sb stuff in a closet somewhere... :) i think i found the speakers... the Adam D3V.
*Fosi DS2 DAC $40
*Fosi V3 Amp $80
I saw this cool youtube review with jaspertech... it sorted my thinking out. Adam D3v...
When I told concentrate on speakers I thought the other way around. Do you have any space or does it have a be on the desk? Is intend still more gaming than anything else regarding headphones?
dang it! I have the deskspace for Adam T5v. I play games. I listen to music.
I want to believe this tiny thing will sound good enough for the 2-4 hours of daily use. I know better...nothing beats displacement when it comes to sound no mater the wizardry...
I mean, Hoffmann's Iron Law always applies - playing low, playing loud, small speaker, pick two. The D3V can play really low for a 3" class speaker, but obviously it won't play deep bass particularly loud. (Using a smaller woofer attacks displacement on two fronts - obviously surface area becomes smaller, but so generally does linear excursion.) It'll do decently at half a meter, but rocking the entire room is not going to happen without compromising on bass output, which is what the bass shelf settings are for.
Having physics on your side tends to make things a whole lot easier and cheaper. You'll be hard-pressed to find any 3-3.5" midwoofer with the level handling of a half-decent 5.25" one, but price wise they aren't actually all the different. Occasionally a good 4.5" will beat a so-so 5.25", but that's about as much as you can typically stretch things without driver cost going out of hand. And I'm not kidding - if you wanted the absolute best drivers, you could splurge on some Purifi ones, but then one of their 4" jobs is going to cost almost as much as an entire decent desktop speaker system.
Likewise, not making your enclosure as small as humanly possible is a cheap way of increasing output. (Note how the most compact of designs also tend to be using passive radiators, which aren't exactly free either. They do avoid having a BR port turn into a hairdryer of sorts at high levels, not to mention the possibility of internal resonances getting out via the port.)
Kali has some prime examples for both, like the LP-UNF (a 4.5" desktop speaker system that can rock a room if need be) or their LP-6v2 monitors (6.5") where you can tell from driver spacing alone that they're not intended for the very closest of distances. In nearfield applications, 5.25" woofers are a very popular size, and you can get very competent budget ones in the $300-400 range per pair. (Note, T5Vs are quite notorious for being hissy, with noise levels even ahead of the classic JBL 305P MkII. You should be better off with the likes of KRK RP5 G5s or the trusty Mackie MR524 if that is a concern. JBL and Focal remain the kings of deepest bass coverage in the 5" class.) By contrast, if you want a maximum of output and deep bass per $ for at least medium distances of 1-1.5 m typ, the budget 8" 2-way class will deliver that although dispersion tends to be a bit less even than for their maller cousins. (Fun fact, the chonky ADAM T8V actually even has markedly less hiss than its smaller brethren, and that's before even taking the larger typical listening distance into account. And the Yamaha HS8 is arguably the most well-rounded member of its series.)
If you are drawn to and can afford ADAM A4Vs for the desk, odds are the same would apply to their direct competition in the form of the Neumann KH80 or the Genelec 8020D (the former being lower noise and louder, the latter having wider dispersion and lower power consumption). Generally speaking this class tends to be approaching "proper" full-range but in most cases falls slightly short still. A bunch of standard 5.25" jobs has similar -3 dB points but lower -10 dB which is a better indication of effective bass coverage. Even some 3" ones are pushed lower (e.g. iLoud Micro, ADAM D3V) but you can tell how much of a stretch that is by how they're dropping like a rock below that.
Anyway, if you're after "classic" monitors with analog balanced inputs, those should probably be complemented with a matching DAC or audio interface ($200-300 should generally do).
HD490Pros are good cans, but there is something to be said about HD600s, too... they're a classic for a reason. I love how undemanding they are. They should work splendidly from the MBP's headphone jack. The PC side may be hit and miss in terms of output impedance and level depending on the onboard audio implementation, but if in doubt you can always spruce it up with a Topping L30 II / Atom Amp 2 / Schiit Magni or similar. Oh, you already have a DAC/amp in the Schiit HEL 2, I imagine that would be just fine as well.
I see relatively little wrong with the DMP-Z8 for its price given its feature set - that being a DAC-amp with a fancy DAC and display and a bunch of connectivity - but the question is whether you really want and need such a singular do-it-all device. What if you concentrate everyone into one setup only to find out that you still need decent sound on the move, on the bedside and in the office?
As much as you might be pedant regarding the placement the distance will never be exactly the same. Hocus pocus is impulse alignment. What I meant whose perhaps stands behind or parallel to table and deacent cheap 6.5" monitors. If you really, really want small the KH80 stands out but that would eat most of your budget alone. Wanted to give you space regarding headphones (hoping both you would talk more about it and someone else would also jump in to help). To squish that out. If you have space and are not too sensitive to a little bit of hiss when not playing and being on something like Kali LP 6 V2's would really be fine. Then you can trow in and stands, better build headphones even a sub if you like (and can have it) for the money. Old HD600 (higher impedance) where rather good if you could find them for a good price. Even new Massdrop HD6XX aren't bad so plenty ways to spare some money if you like not even moving away from Sennheiser. However I would still suggest something a little bit different if the gaming is purpose.
Why make it so complicated? A good audio interface like the Motu M2/4 or any of the other numerous competitors has almost perfect DAC quality, a usually good headphone amp, and a <$300 price. Then, get a couple of great value speakers like the Kali LP-6v2 for $200 each plus a subwoofer for $500, and then use the rest on whatever headphones are highly rated on ASR. That is the exact setup I had until yesterday and basically nothing else comes even close in sound quality and comfort if you don't want to put something in/around your ears
