As I understood, majority of members consider the signal as similar to the source as possible and after make some voluntary modifications for room corrections or just for pleasure.
Yes, that’s what I was responding to. When we are talking about possibly pleasant distortions in our systems, the common view here is that you should start with a totally neutral system, and then if you want to add any form of distortion you can do so with EQ or possibly plug-ins if you’re looking for a tube like distortion .
This is of course, an entirely sensible approach.
I only push back a little bit when it is presented as the ONLY sensible approach.
As I constantly argue: a sensible approach depends on the individual. There’s no one size fit’s all sensible approach.
What seem to be a nonsense is to voluntary choose a piece of gear that distorts, because one cannot probably undo the process: will always carry the harmonics.
Or perhaps is not a nonsense, but is a minority choice (for me as illogical as buying a camera with a non transparent objective that you can’t leave if you want)
Yes, a minority approach. At least in terms of this forum.
Within this context , I’ve explained/defended my choice of using old tube amps but here it goes again in case it is of interest to you:
1. I like gear, how it looks and how it feels, and for me tube amps are just cool! Always have been. I love the way they look. I like the concept. I like the connection to the history of audio that they represent. To me virtually all solid state amplifiers are just utilitarian boxes.
They don’t do a thing for me, aesthetically or conceptually. Whereas I swear whenever I fire up my old tube amps I still feel kind of giddy and love the glowing tubes. So right off the bat, that’s something that I’m not going to get from the type of system most here think is “the right way to do things.”
2 I personally enjoy some level of personal input in the sound of my system. In other words, my goal isn’t some totally neutral system that will sound just like your neutral system. I’m looking to participate somewhat in achieving exactly the sound that I want to hear.
That brings us back to: well then why not start with a neutral system - usually meaning solid state - and EQ it to your hearts content or add VST plug-ins if you want to like distortion? Then you can turn them on and off too!
Why not? Because for one thing, as I said, I really like tube amps! The above simply would not actually give me a tube amp.
Further, I have also had solid state amplifiers in my system on and off over the years, if not for long, as well as a digital parametric EQ. I tried a few times, but never could duplicate the sound I perceived from my tube amps just by using EQ with a solid amp. And I have no interest whatsoever and trying to introduce awkward VST’s into my system. Yuck. Which also are not guaranteed to replicate the sound I already know I like in the particularly tube amps I own.
3. The flexibility to turn the distortion on and off is only a big plus if you actually end up wanting to turn it off. But I don’t want to turn it off. I’ve never wanted to turn off the distortion from my tube amps. The reason I got them is that I love how everything sounds played via the tube amps! No need for fiddling, for me it’s a set and forget solution for the sound I tried to achieve. Along with all the aesthetic and conceptual aspects, the tube amp gives me.
4. Ultimately the level of distortion from my tube amps is subtle. It’s significant to me, but in the big picture is not nearly enough distortion to “make everything sound the same” or override the different Sonic characteristics of recordings. So I’m not worried that I’m denying myself insight into how the different recordings sound, which is something I also appreciate.
So with all that said, I hope that you can appreciate that while it certainly wouldn’t be a solution you would select, this alternative approach does make sense for my taste and goals. I’ve been thrilled with my amps for 25 years!
And a great many other audiophiles, though typically not ones who would join us site like this, have found great pleasure, and success in this non-ASR approach of putting the distortion wherever they want it.
(Which can be acknowledged without endorsing every woo thing audiophiles believe)
