Apologies for the click-baity title but... I do not understand the logic behind the "subwoofer" crawl. Maybe I do not understand the physics properly: I understand that the lower a frequency is, the more "omnidirectional" it is... However, any given cone needs, by definition, to face one direction. With this being true, doesn't the direction which you place the woofer in effect the... effect? For example, in the room that I currently use for my home theater (I will be moving it) the room is open into a hall way and front room on one side; the opposite side is a wall and windows (where the tv is). If I place a subwoofer on the couch, it will be facing the tv wall; if I place the subwoofer on the tv wall, it will be facing the open area. So how could this not give a different effect?
In any event, I just tried near field placement, for the first time, a couple hours ago. This is incredible, I have no idea why I hadn't tried it soon. I have my svs pb-1000 placed, on a small end table, directly behind my loveseat (MLP). I have never had such great bass, and the tactile effect is WAY better than anything I've got from transducers. If I could spare the sb1000 from my music setup I would add that also (maybe I would put the sealed behind the MLP, and the ported somewhere else in the room, in case other people are here... not likely).
Thoughts? Sorry for the long post.
