Linearity, noise, noise corner, grid current.What were you testing for? That is interesting. 6DJ8s, a vhf tube can be tricky. The best I have are bugle boys that were tested for noise and microphonics some 50 years ago by ARS in Calif.
We've a fair bit of overlap.
Check out jpjones3's music collection on Discogs
Dig through jpjones3's collection on the world's biggest online music database and marketplace & start cataloging your own. Happy Collecting!www.discogs.com
Generally, maximum voltage gain, grid to plate. dVp/dVg at constant plate current.I have to admit.
I still can't figure out what the heck mu is
It’s related but not the same. It’s the gain only under a constant current condition. If you have a load on the plate, the gain will be lower than mu.And is there a reason they didn't call that just 'gain'?
That's freaky.
But you've got some classical on LP, which I relegate to RTR and digital.
What is Mu-metal?I still can't figure out what the heck mu is
What is Mu-metal?
Mu-metal is a nickel-iron alloy with very high magnetic permeability that has a low coercivity that saturates at low magnetic fields, resulting in excellent shielding properties. Magnetic shielding works by redirecting the propagation of magnetic field lines so that magnetic flux flows through the walls of the shield itself, by-passing the inside of the vacuum chamber.
Chemical Composition:
MuMETAL® Chemical Composition % In Weight*
Nickel (Ni) 80-82%
Molybdenum (Mo) 3.5-6%
Manganese (Mn) 0.8% max
Silicon (Si) 0.5% max
Cobalt 0.5% max
Copper 0.30% max
Chromium 0.30% max
Phosphorus 0.02% max
Sulfur 0.01% max
Carbon (C) 0.05% max
Iron (Fe) Balance
From <http://www.mu-metal.com/technical-data.html>
Then, there is that other 'mu' or the greek letter μ, which represents one millionth, or 1e−6.
They seem to be solidly digital these days. Although, they have a number of refurbished and new, old stock analog units they'd be happy to sell you. $20,000 and up.Isn't Nagra reviving their line?
... I then added to the phoolery by spending about $400-500 rolling tubes FWIW, I currently run Amperex 'PQ' USA white label 6922's.
P'haps this one:None of those
