TempoTec Sonata BHD Pro Portable DAC & Amp Review
Rate this DAC & HP Amp
    Votes: 5 1.9%
    Votes: 8 3.0%
    Votes: 27 10.2%
    Votes: 225 84.9%
cheapmessiah
Mordor
@amirm I hope I'm not mistaken but this seems to be the Sonata BHD Pro version.
I'm also wondering if this could power an amp since it is 2v/4v unbal/bal output.
JeremyFife
Scotland
Thanks for the review, looks great.
Hope you are feeling better soon @amirm
FrantzM
Amir, why do you review and recommend things? First it was the Dan Clark Stealth and I had to buy those; now it's this dongle, which I've just ordered. Are you trying to send me to the poorhouse? (Admittedly this dongle was a lot easier to buy than the Stealth 'phones. But still...)
+1
I will also purchase it. Will pay with my credit card. And , send the notarized invoice to @amirm. Will update the collective on his response.
:p
Peace
AdamG
Enjoy the Music your way…
Moderator
Reality
I think you are correct. This does look to be the Pro model. FYI @amirm
Gadgety
Great to see it tested. Tempotec also has the Sonata HD Pro at half the price, which uses one CS14131 vs two used in the BHD. It seems to get favorable reviews and has DAC performance that isn't far off the BHD in terms of the (rather sparse) specs Tempotec presents. Would be nice to see how that compares.
staticV3
ZolaIII
Amir tested it long time ago and it did better than Wolf's sample while Amir's Hidizs S8 (all the same) did even better. We had discussions about it and Meizu dongles then... And it's about 30$ right now on Ally for Android (cable) version (as close to Meizus promise as it could be regarding price).
AudioSceptic
Northampton, UK
Thanks for the review @amirm
Isn't this the "PRO" version? I have the impression that the tempotec sonata BHD looks different and has a cable attached.
This pro version is also more expensive I believe (90$ tempotec shop)
Yes, looks like it, even though it doesn't seem to say so on the device itself. £69 at Amazon UK.
Jimbob54
That's a good price but if its the same listing I've just looked at... It's an amazon us import with 1 to 2 month wait. Not sure how fees and taxes are handled I this scenario either,
AudioSceptic
Northampton, UK
Bicep
As someone quite new to all of this. What would be the benefit of using a smsl su1 compared to this in a desktop setup?
Jimbob54
CleanSound
Price went up.
I wonder if they upped the price after this review was published.
