Here's the product page: https://www.fiio.com/ka13
I intend to order one to ship it for review.
Specs list compared with other similar FiiO products:
Model | KA13 | KA5 | KA3 | KA1 | KA2 |
Color | Midnight black/Dawn silver | Classic black/Electrophoresis white | Classic black | Classic black/Midnight green | Classic black |
DAC chip | CS43131*2 | CS43198*2 | ES9038Q2M | ES9281AC PRO | CS43131*2 |
Op-amp chip | SGM8262*2 | SGM8261*2 | RT6863D*2 | N/A | N/A |
FiiO Control | Supported | Supported | Supported | Supported | Supported |
Dimensions | About 56.3*22*10.5mm | About 56.3*22*12mm | About 56.3*20.2*12mm | Body: About 40*15*8mm Cable: 70mm | Body: About 40*15*12mm Cable: 70mm |
Weight | About 18.5g (excluding cable) | About 19g (excluding cable) | About 17.5g (excluding cable) | About 10g | About 12.3g |
Audio input | Interchangeable Type-C cable | Interchangeable Type-C cable | Interchangeable Type-C cable | Type-C or Lightning cable | Type-C or Lightning cable |
Headphone output | 3.5mm PO 4.4mm BAL | 3.5mm PO 4.4mm BAL | 3.5mm PO 4.4mm BAL | 3.5mm PO | 4.4mm BAL |
SPDIF output | 3.5mm coaxial out | 3.5mm coaxial out | N/A | N/A | N/A |
Physical button | Desktop mode switch/Volume adjusting button/Song switching button | Menu setting, Function switching, Volume adjusting, Play/Pause | N/A | N/A | N/A |
Display | N/A | OLED display | N/A | N/A | N/A |
Sampling rate display | RGB indicator light Blue: 48kHz and below Yellow: Above 48kHz Green: DSD | On-screen real-time display | RGB indicator light Blue: 48kHz and below Yellow: Above 48kHz Green: DSD | RGB indicator light Blue: 48kHz and below Yellow: Above 48kHz Green: DSD Magenta: MQA | RGB indicator light Blue: 48kHz and below Yellow: Above 48kHz Green: DSD |
Supported sampling rate | PCM: 384kHz/32bit DSD DoP: 64/128 DSD Native: 64/124/256 Coaxial: 384kHz/32bit | PCM: 768kHz/32bit DSD DoP: 64/128/256 DSD Native: 64/128/256 Coaxial: 192kHz/32bit | PCM: 768KHz/32bit DSD DoP: 64/128/256 DSD Native: 64/124/256/512 | PCM: 384kHz/32bit DSD DoP: 64/128 DSD Native: 64/128/256 MQA: 16x | PCM: 384KHz/32bit DSD DoP: 64/128/256 DSD Native: 64/124/256 |
Output amplitude | PO>2.3V (32Ω/THD+N<1%) BAL>4.2V (32Ω/THD+N<1%) | PO>1.99V (32Ω/THD+N<1%) BAL>2.9V (32Ω/THD+N<1%) | PO> 2V (32Ω/THD+N<1%) BAL>2.7V (32Ω/THD+N<1%) | PO>1.2V (32Ω/THD+N<1%) | BAL>2.2V (32Ω/THD+N<1%) |
Output power | L+R≥170mW+170mW (32Ω PO/THD+N<1%) L+R≥550mW+550mW (32Ω BAL/THD+N<1%) | L+R≥122mW+122mW (32Ω PO/THD+N<1%) L+R≥265mW+265mW (32Ω BAL/THD+N<1%) | L+R≥130mW+130mW (32Ω PO/THD+N<1%) L+R≥235mW+235mW (32Ω BAL/THD+N<1%) | L+R≥45mW+45mW (32Ω PO/THD+N<1%) | L+R≥153mW+153mW (32Ω BAL/THD+N<1%) |
SNR | ≥122dB (32Ω/A-weighted/PO) ≥122dB (32Ω/A-weighted/BAL) | ≥124dB (32Ω/A-weighted/PO) ≥128dB (32Ω/A-weighted/BAL) | ≥122dB (32Ω/A-weighted/PO) ≥119dB (32Ω/A-weighted/BAL) | ≥114dB (32Ω/A-weighted) | ≥125dB (32Ω/A-weighted) ≥131dB (600Ω/A-weighted) |
Noise floor | PO<1.7μV (A-weighted) BAL<3.1μV (A-weighted) | PO<1.6μV (A-weighted) BAL<1.8μV (A-weighted) | PO<2.3μV (A-weighted) BAL<2.9μV (A-weighted) | PO<2.4μV (A-weighted) | PO<1.7μV (A-weighted) |
Output impedance | <1.7Ω (32Ω loaded/PO) <1.8Ω (32Ω loaded/BAL) | <0.3Ω (32Ω loaded/PO) <0.35Ω (32Ω loaded/BAL) | <0.5Ω (32Ω loaded/PO) <0.7Ω (32Ω loaded/BAL) | <1.5Ω (32Ω loaded) | <0.5Ω (32Ω loaded) |
Channel Separation | ≥72dB (1kHz/32Ω loaded/PO) ≥110dB (1kHz/32Ω loaded/BAL) | ≥72dB (1kHz/32Ω loaded/PO) ≥115dB (1kHz/32Ω loaded/BAL) | ≥91dB (1kHz/32Ω loaded/PO) ≥106dB (1kHz/32Ω loaded/BAL) | ≥73dB (1kHz/32Ω loaded) | ≥91dB (1kHz/32Ω loaded) |
THD+N | <0.0005% (32Ω/PO) <0.0005% (32Ω/BAL) | <0.00037% (32Ω/PO) <0.00037% (32Ω/BAL) | <0.0008% (32Ω/PO) <0.0010% (32Ω/BAL) | <0.0005% (32Ω/PO) | <0.0005% (32Ω/PO) <0.00024% (600Ω/PO) |
Power consumption | 140mA (standby) 150mA (PO/40mV) 150mA (BAL/40mV) | 110mA (standby) 113mA (PO/40mV) 113mA (BAL/40mV) | 120mA (standby) 130mA (PO/40mV) 130mA (BAL/40mV) | 50mA (standby) 60mA (40mV) | 80mA (standby) 85mA (40mV) |
