Swan dive into the D class
fpitas
Northern Virginia, USA
Please be more accurate. Where and how?
I'm not sure I understand the question. To be sure though, please link what you saw from Benchmark.
D
Deleted member 48726
Guest
The link is posted further up in this thread.
I mean: break down and explain where and what is wrong with his calculations. I can't fault them but I am not an electrical engineer per se and may have missed some errors. If the errors and mistakes were to be shown and explained I may even learn a thing or two.
fpitas
Well, I'm at work, and I can't immediately find it. I'll scour the thread later.
D
Guest
Waiting for an explanation why this is wrong.
D
Guest
Liquid helium's been in short supply for a while, which certainly doesn't help! :cool:
If you don't mind explaining where the calculations are wrong and why instead of delivering gnarly remarks where it's suggested you know better, that would be appreciated.
There are a few loose ends in this regard.
fpitas
Wrong? No, that's not what I said. Very optimistic, since they do consider cable resistance (that's good), but they don't consider passive crossover inductor DCR (that's bad). They get a DF at the speaker terminals, but if that speaker has a 0.5 ohm (let's say) DCR inductor to the woofer, obviously matters are a bit different than they suppose.
Don't get me wrong: I'm all for a good DF. That's one reason I went active, with the amp connected directly to the woofers.
Benchmark makes great amps, but they're not responsible for what goes on inside your speaker.
