Suggestions sought - using PC or Mac as a crossover with some added complexities
Olli
What about this: https://rogueamoeba.com/audiohijack/
Krunok
Zg, Cro
Oh awesome :)
I’m going to research and think through this a little more and eventually likely hit you up about this...
What can be implemented now via BruteFIR plugin for Volumio is not only dynamic EQ feature you desccribed but also a feature implemented in Devialet SAM where different filters with higher bass extension are activated as volume raises to keep woofer from excessive excursion. ;)
andreasmaaan
andreasmaaan
Keep us posted Andreas, as I'll want to use the same pathway as you for my project:
PC with a OS --> Spotify/Tidal/VLC/Kodi/Firefox --> A system-wide EQ (Room EQ) --> Digital XO (FIR) --> Multichannel Dac --> separate amps.
Will do :)
Biblob
I notice it too. Must be very recently. Looked at it couple of days ago.
Biblob
Ah yes. It's back again. Maybe an update :)
somebodyelse
BrutefirDrc (a plugin for logitechmediaserver to do the convolution on the server end) did loudness by piping the audio from the virtual sound card through sox loudness function before passing it on to brutefir.
DDF
There's always the Bozio ultimate equalizer. Very high functionality including 4+ way xovers, phase EQ and low frequency room eq
http://www.musicanddesign.com/Ultimate_Equalizer_promo.html
Experienced DIYers report good success (eg DLR here):
http://techtalk.parts-express.com/f...-running-on-pc-platform?p=1114573#post1114573
The Bozio SW UI is reputed to be a chamber of horrors so I've yet to take the plunge.
Edit: one more option, though I've not come across any feedback:
http://www.thuneau.com/allocator.htm
Olli
Thanks! I still haven’t found a software crossover for Mac, but this is a good start.
Andreas, you can generate XO and Filters on a windows machine (eg w/ Audiolense) and use just any convolver on a Mac or PC. I use Roon on a Mac, for example.
With Loopback you can run any source - Browser-, App- or Hardwarebased. So you could even route your Turntable through if your DAC has an analogue input.
Just found something that seems to be the equivalent for Windows: https://www.vb-audio.com/Cable/
andreasmaaan
andreasmaaan
Thanks everyone. Lots of interesting ideas to follow up on here :)
Krunok
Zg, Cro
In short, it's EQ that is only activated when the input drops below (or above) a certain threshold level. In this case, it would be used to boost low frequencies when the volume dropped below a certain threshold, to compensate for the hearing system's nonlinearity (equal loudness curves).
How many volume levels/fitler sets do you think a system should have to effectively implement dynaimc EQ (loudness + LF reduction on high volumes)?
andreasmaaan
andreasmaaan
Ideally, it isn't discrete at all.
For example, this is a dynamic EQ VST plugin set up to kick in only when the signal drops below -20dBfs (the "threshold"). The magnitude of the bass boost is then inversely proportional to the level of the input, so that at -20dBfs the boost is 0dB, and at -X dBfs the boost is +18dB (this is just an example btw, it's not supposed to be correct necessarily):
Krunok
Zg, Cro
Heh, I know it would be best if it isn't discrete, but with BruteFIR it can only be implemented by changing the filters based on volume change. I am basically asking for your opinion what do you think would be a "reasonable" number of filters to implement in that scenario? It is also a question how many filters would folks be willing to generate in order to achieve such functionality.. :)
andreasmaaan
andreasmaaan
Fair enough :) In that case, I'm not sure, will have to think it through. Perhaps others have thought about it already? Maybe 4 would be "enough"?
Krunok
Zg, Cro
I was thinking about 5. :)
So, is yellow line on your graph for quiet playing and blue line for very loud?
andreasmaaan
andreasmaaan
Not quite, no. Above -20dBfs, the output is flat. Below -20dBfs, the output gets closer and closer to the yellow curve, reaching it at a level determined by the "ratio" setting.
