Suggestion on budget "thumb" DAC/AMP for laptop
uzapuca
Hi guys,
Would you help out with some suggestion on a budget portable DAC/AMP for laptop? I will mostly listen with IEMs like Shure or KZ headphones. I would like to move in a budget from U$D 50 to 100 max. Something to take to work everyday.
I have read some reviews for the XTreme Pro
https://www.newegg.com/p/2GA-003S-00001?cm_re=xtrempro-_-9SIAGP07AA3617-_-Product
Dragonfly Red is out of budget but maybe there are some good deals in the middle that can fill the spot. Some FIIO model perhaps? there are some many of them than tends to be confusing.
Thanks for your help and ideas.
Cheers,
twsecrest
California
Have you tried or used? I did a google search and What Hi-Fi just killed, hehe. It says "Doesn’t improve sound quality – quite the opposite, in fact"
The FiiO K1 was the best low cost option, for $100, you could get the FiiO K3.
DosThou
U
uzapuca
Thanks for the idea Twsecrest!
I will check more review on the FiiO K3. ;-) it does look quite portable and powerful for its size.
U
uzapuca
raise your budget a bit more and you'd have these two very good options:
https://www.audiosciencereview.com/...w-and-measurements-of-sound-blasterx-g6.7016/
or
https://www.audiosciencereview.com/...asurements-of-musiland-mu2-plus-dac-amp.6964/
first one is much easier to get and probably pair better with more devices that doesn't support UAC 2.0 though. edit: oops, I guess G6 is a bit too big for your requirements?
Thanks for the data DosThou!
The Sound BlasterX G6 seems nice, but for $150 it is a bit too much considering my desktop setup will be Atom and OL Dac coming soon.
The Musiland sounds interesting. A concerning issue is the dongle cable which seems to be attached internally to the thumb drive. If you break the cable no more amp, i guess.
I just saw a Z Review and he was suggesting the Micca OriGen as the best price per pound combination all in one set for a U$S 100. Maybe is a bit too bulky for a portable convenience. What do you think?
dc655321
Similar to the Dragonfly Red, but better performing and 1/2 the price (or less), is the SMSL iDEA.
IMO, a great little device. It has been measured several times on this site and others.
DosThou
Well MU2 Plus is only $20 less than G6 so that's out of question regardless. And yeah, the cable issue is real.
I do not recommend OriGen based on Amirm's findings... https://www.audiosciencereview.com/...measurements-of-micca-origen-g2-dac-amp.4805/
You could also opt for Fiio BTR3, which can function as either a bluetooth receiver or a stand alone DAC. Been hearing good things from people who got one in my local circle, but no measurements exist as far as I'm aware.
U
uzapuca
Thanks for the interesting info on the SMSL IDEA!
I just found out it has the same chip that Marantz use in some of their high-end amplifier series. So that looks good indeed.
Just curious, do you know where is reliable place to get it? Amazon or Ali Express? Ali Express has some many different vendors that cannot tell which might have a good seller reputation.
U
uzapuca
Thanks for the good data DosThou,
Good point on the OriGen. Z reviews sound very convincing at times that it is easy to get carried away...he...he.
Never heard of the FiiO BTR3. I will take a look online. Is it new that has no measurement yet?
andreasmaaan
Thanks for you suggestion Andreas,
Sorry that your reply went over my head and i guess i did not understand the idea. You meant that the Apple USB-C dongle works as DAC/AMP? o_O
Exactly :) It's performance is as good as anything measured here costing under $100, and it has low output impedance which makes it very suitable for IEMs. What it doesn't have is a volume control, which means you'd need to control volume with software. There's nothing wrong with this however (arguably it's the best way to control volume from a fidelity perspective, with a few caveats depending on the software and the IEMs).
The SMSL Idea measures equally well though and also has very low output impedance. You couldn't go wrong with either IMHO. I bought the Apple dongle because it was cheaper and easier to find where I am. It needs a USB-C adaptor to plug into a laptop; I bought one for a few euros from an electronics store.
U
uzapuca
Thanks again for your info Andreas,;)
I thought the Apple dongle was just a plain connector without any pre or amplifier features. Everyday, you learn something new, i guess...haha. As you can see i am very new to all audio issues. I thought the iPhone or Macbook Pro sound card were considerably poor quality because of space issues so that i why i needed an external pre / amplifier to improve the quality of sound to a good solution.
Just curious, what is your usual setup regarding portable and desktop?
andreasmaaan
I have the Apple dongle which I use for my laptop and headphones/IEMs. I run Equalizer APO to correct the frequency response of my headphones.
Then I also have an RME Adi-2 DAC that was in the home system (which is out of action at the moment), and a MOTU Ultralite that I use in the studio and for loudspeaker measurements.
All three sound perfectly transparent to my ears.
U
uzapuca
Thanks for the good insight Andreas!
You seem to know your stuff. So are we naive for getting a portable DAC / Amp for IEMS and a Macbook Pro? :D I mean if can later fix the sound with VOX EQ could i tell the difference with or without an Amp?
