It’s semantics right?
Like Bo Thunér’s system.
It probably plays deeper and louder and cleaner than 99% of all home stereos in his town.
Judging by his cabinet, that’s 20” wide, which means in his cabinets are eighteen inch woofers, per side.
So no, he doesn’t need a typical 10-12 inch “subwoofer”
When people ask about subwoofers,
what they mean to ask is-
Do I need deeper bass?
Or louder bass? (Or both)
Well to answer that question that all depends on how loud you intend to play?
Is your room like an apartment in Tokyo or a living room on a country farm in Boyup Brook, Western Australia?
But to get more SPL at lower frequency it’s all related. My Google Nest Audio can play 50-100Hz; at maybe 70dB @ 1m.
If I want 20-40Hz at 90dB I need a bigger woofer, or a woofer with more excursion (or both) for more air volume displacement, and/or a bigger cabinet.
Whether you want to have biggest woofers separated, or built into your main speakers all depends on aesthetics and convenience of placement vs smooth bass response around the room.
The most interesting thing is if Bo separates his cabinets; whether moving the bass bin around the room would give a better bass response at his listening position(/s). And the only way to know that it via measurements, trial and error and then reworking his crossover. Whether 3 woofers is better than 2, or 4 woofers is better than 3 that all depends on the particular room, and can’t be judged without measurements. Sure if you didn’t have measurement ability you could plonk down 3-6 (or more) subwoofers throughout for room and it might result in smoother bass response when you walk around. The downside is a variety of other practical issues too.
Now if Bo wants to play his DJ set to an audience of 300+ people outdoors over an area of 1000m^2, he may need extra subwoofers.
