subsonic/infrasonic test for the gear reviews
BeerBear
The Apple USB-C dongle apparently has some trouble with very low frequencies, it produces some noise/distortion/clipping when playing such content. The problem is easily audible, but Amir's review didn't show it. So maybe adding something like this to the reviews would be useful.
But I can't estimate how much audio gear is affected by this issue. After all it's possible that it only affects this Apple dongle. So to get more data, I invite users to check this with their own gear (DACs, amps...). I attached a couple of audio files you can use, but you can also use something else.
(edited for clarity)
Before I download your file what are you testing for exactly. Just low end response? The issue might be in the measuring device. I was informed a few months back and was shown how most DACs now will do full response down to DC. ADC's usually will block that however.
Any kind of distortion/noise/crackling. For example, the 3Hz test tone should not produce anything audible at all, but it does produce some "ticking" noise with the Apple dongle. It's probably easier to hear this with headphones, BTW. You can record it if you want/can, but it's not required.
Wait, let me get this straight. You play a 3hz tone through your speakers and headphones which causes them to make ticking noise, and you assume this is the Apple dongle that is doing it, not the headphones/speakers, is that correct?
