Because he didn't use a mono or two different tones in his testing.Maybe a stupid question, but why didn't amirm find this kind of problem in his testings (e.g. SU-9)?
Because it wasn't tested for. The problem I'm seeing is that it's still not being tested for nor has it been acknowledged in any way by the host. 2nd to the SMSL response, that's the most disappointing thing. Oh well, so much for science.Maybe a stupid question, but why didn't amirm find this kind of problem in his testings (e.g. SU-9)?
I think there are also a lot of newbies who just read the first page and will buy the product because of its great results.
On the other hand, I read this device performance in the range of a 150$ device, how is that possible, regarding to the results in the actual review?
But that's fine! I've been an engineer for 25 years snd I still miss stuff. Much less than I used to, but still I miss. I've always fully accepted and changed course on a miss. Seems that lesson is missing among our host.The problem ASR has in acknowledging that their SINAD testing methodology is flawed (only testing stereo devices with a mono signal) is that it potentially invalidates all the DAC tests in that the SINAD measurements are only certain when DACs are played in mono. In the best interests of audio science the SINAD chart should be marked accordingly.
Not really to be completely fair, as they're pretty standard tests for audio products. If it was a hardware issue you'd only have one channel working at all and would see/hear this straight away. This is not a hardware issue at all, but a firmware error in the channel mapping (likely) so it should only affect units that use this same topology and firmware for the es9038pro only. I can't say for sure, but I'd imagine Amir would be checking this now quietly, but won't post the results unless a similar issue ever shows up again. We and Amir also don't know if the original unit tested was a golden sample... this is why I posted at some point in this large thread that if SMSL are going to use ASR testing to promote their products, then the door should swing both ways, yet we have no contact here from them at all.The problem ASR has in acknowledging that their SINAD testing methodology is flawed (only testing stereo devices with a mono signal) is that it potentially invalidates all the DAC tests in that the SINAD measurements are only certain when DACs are played in mono.
You can test all the tests for all sample rates and for left, right, both channel.@JSmith, but why not accept the miss in measurement coverage, learn from it, and improve. Measurements are great, but ultimately useless if they don't fully cover all use cases. It's a major miss that should be learned from.
There are just too many tests. Any one of them can go wrong.
Is my DAC garbage? Were the measurements reported in Amir's review not repeatable in actual home setups? Basically should I get rid of the SU-9 and buy some other DAC and would that be audibly superior due to the faults in SU-9, if yes...in what way? I feel I am defrauded yet again by SMSL and all I want now is to assess the extent of damage. Finally what's the solution available to me or other users to correct the situation?
Just trying to understand this measurement part of your comment. I run my DAC fed from Roon via USB balanced to the Amplifier. Amir did the SINAD and other measurement tests... assuming his unit wasn't a golden sample, those results were jaw dropping. Why then now the measurements for SU 9 are garbage and lower even than the Topping D10? Is there a specific setting/use case in which the measurements suffer...coz I'd imagine Amir's tests would otherwise reveal all relevant issues as he does tests dealing with factors affecting real listening scenarios/metrics.As far as measurements go, yes, it is absolute garbage
Hi guys, I've received the package from SMSL today. In it was a USB cable and a Jlink debugger:
It didn't come with any instructions or firmware, it might be flashed on the micro controller? I have no way to tell.
I opened up my unit and it was quite easy to find the socket for the flat cable.
I connected the flat cable and the micro usb cable to the jlink debugger. I turned on my unit.
Everything seems to be working but there was no UI indication about any process (no progress bars, no update notification, nothing...).
I've reached out to SMSL to see if they can provide me with instructions.
I'll update once I have some more details.
Also, what SINAD value are we looking at as the revised number (estimated)?
And audibly, what subjective ques should be affected, is the darker sound of this DAC due to this issue as well? If you see there is a clear tilt in what seems to be diminishing higher frequencies linearly...again a linearity test passed with full marks when Amir did it.
Something doesn't quite fit well in the story. Why were audible issues not detected in Amir's tests, I wonder!
Thanks for the clarification.
Ah right. Extrapolating anything a continent of 4,5 billion people can do from...the performance of a DAC made by a small company in Shenzhen.Seems typical asian experience, you are promised something and given something far inferior...
So you watched a movie with a DAC... please, tell me more.this movie
