Please can you let us know what do they do right, while you are it, can you please provide us with any measurements outlining their superiority in said areas ?
If they got paper cones for example they sound very natural.
No idea how to measure this.
I said no such thing. All I've said is I agree with the research as I have no scientific basis from which to disagree with it. You don't either, but that hasn't stopped you from disagreeing with it.Well sure, if you believe that room magically stops influencing speaker's response at transition frequency like it hit the invisible wall, well whatever rocks your boat I'm fine with it.
Oh, hell ya!
Not only this but also a bad off axis, response.Yes, but unfortunately they have a deficiency of not so linear frequency response over the audible range which is more important than time-alignement.
.... Mmmmmm.... They have too many significant drawbacks.Fullranges have their drawbacks also but some do so many things right that it doesn't matter (for me at least).
I use a custom enclosure and a phaseplug kind of thing on my triple cones.
Nice natural sound.
After listening to fullranges for a while the sound of multiways seems to be torn/disunited to me.
Have you listened to the Fane Sovereign 12-250TC or the Fane Sovereign 15-300TC?.... Mmmmmm.... They have too many significant drawbacks.
I'm afraid you can't. It's a fundamental problem of cone size V signal wavelength.True but you can combat this using phase plug like methods.
A 12" driver will beam high frequencies.Have you listened to the Fane Sovereign 12-250TC or the Fane Sovereign 15-300TC?
The 12 inch changed my mind.
Yes it will by nature.A 12" driver will beam high frequencies.
Did you measure it?I used a V-shaped vertical rod in front of it.
Worked for me.
So it's off axis response is going to be all over the place.Yes it will by nature.
Did you measure it?
Are you seriously using this and consider it full range? It's 20dB down by 10kHz!Have you listened to the Fane Sovereign 12-250TC or the Fane Sovereign 15-300TC?
Are you seriously using this and consider it full range? It's 40dB down by 10kHz!
Are you seriously using this and consider it full range? It's 40dB down by 10kHz!![]()
The measurements are there in front of you. It does no such thing.It is not.
Due to the triple cones it will go up to 18kHz easily.
