As a 8c owner, I am strongly biased, but the way Dutch&Dutch has been backing up the product and how they are interacting with the user community is nothing short of extraordinary.They are doing a lot of things right.
Yes he did, 2025.Didn’t he also recently state that ‘sub out’ firmware would be implemented by next year?
Yeah, I hear you. Who wouldn’t want a lower price? That said, the 8c is expensive to produce. When you consider what you’re getting, it’s a fair price. In fact, many of our hi-fi customers switched to the 8c from much more expensive and complex setups. Surprisingly, not only did they simplify their systems, but in most cases, they also noticed an improvement in sound quality. Therefore, depending on your perspective, you could even argue it offers great value for money.
Latency isn't an issue here. In low-latency mode, it's around 3 milliseconds, about the same time it takes sound to travel one meter through air. In linear-phase mode, it's about 30 ms, but that's expected if you want 4th order crossovers and flat phase response. The crossover filters cause some frequencies to be delayed relative to others. The phase-linearization filter simply delays all frequencies equally, so they align perfectly in time.
The internal DSP computation time is negligible. Most of the 3 ms delay comes from the ADC and DAC.
I get where this "beef" is coming from. The 8c does have a subwoofer output, but the setup interface still isn’t developed yet, as other features have taken priority. That said, I’m curious: what other speakers are you comparing it to that do offer a fully configurable subwoofer output? There are very few out there, if any.
Alright, you’ve heard it here first: this particular issue will be resolved in 2025.
Sounds like we need to clear up the fog. What is unclear about it? Perhaps I can help lift the haze.
I agree in principle. I’ve done plenty of ABX blind tests comparing Spotify's 320 kbps Ogg Vorbis to lossless. When focusing on specific half-second audio fragments, I could reliably tell the difference after some practice. But during normal listening, the difference is imperceptible to me.
Made me laugh Frank. Embrace your grumpiness.
Lol sorry I accidentally posted it here and deleted itIs that the new 6C PJ, Martijn has certainly changed design direction
I might even like a remote control if it had a rotary volume control. But, until something does have that, I will for sure stick with my Apt/Holman PreAmps, I don't stream, I don't have a TV (not since 2007) & don't need to change the volume very often, anyway.IMO if the product is good when you buy it updates are not necessary and may even be functional downgrades if you have an unusual way of using a product.
I understand 'phone vendors keep slowing theri phones to make a new one attractive, even when the one the customer has can do everything they need, and computer makers do the same but with speakers I see no need for updates, so service and availability of spares is more at issue.
My problem with most modern music systems is lack of a rotary volume control, preferably on the remote control, which rather rules out computer based audio![]()
There was a Quad preamp which had a rotary volume control on the remote and so do the Devialet amplifiers I use.I might even like a remote control if it had a rotary volume control. But, until something does have that, I will for sure stick with my Apt/Holman PreAmps, I don't stream, I don't have a TV (not since 2007) & don't need to change the volume very often, anyway.
I do get up to change formats (or flip albums, which I have usually put on high quality cassette [yep, I still play those] or burned to a CD), so that I can listen all the way through.
As to hearing the high end, these days 15KHz is about my limit, so...
Had to look that up, never heard of it. Don't think it was ever imported here.Apt/Holman PreAmps
Designed by Tomlinson Holman, the inventor of 5.1 and all later surround formats, the Chief Engineer on the ADVENT 300 Receiver. You should Wiki him, a very interesting history in both audio & cinema audio, a former Microsoft employee, a former Professor and more.Had to look that up, never heard of it. Don't think it was ever imported here.
@Martijn Mensink
I am an 8c owner and have moved my speakers into a very large room where I am maxxing out the subs with EDM at higher volumes. I don't see this as a failure of the 8c's, the room is just very large. I'm now very interested in adding a sub or two to augment the bass. Is the subwoofer output issue still on track for resolution in 2025 and do you happen to have a D&D subwoofer in the pipeline? I'd much rather stick with all D&D hardware if possible. Thank you.
Hi cEbNVDyfMy (did I get that right?),
Yes, the subwoofer-output configuration is still on track for release this year and is currently in beta testing. We don’t have plans for an 8c subwoofer at this time.
Best regards,
Martijn
MartijnHi cEbNVDyfMy (did I get that right?),
Best regards,
Martijn
