Speaker Stands - desktop/office set up - is it just me…?
Yorkshire Mouth
God's County - Yorkshire
My current set up is a desktop affair, with speakers on stands either side of the desk. It’s a work in progress.
I don’t know why I’ve not thought about this before, but sat in an office/gaming chair, you’re ears are far higher than if you’re sat on a sofa, or in an armchair.
If my sums are right, I believe I’ll need stands which are 95cm tall. I’ve found some, but they’re thin on the ground.
Is it just me, or do others find this is an issue?
staticV3
Desk clamp monitor stands seem like an obvious solution:
CT Man
Maybe this. Height adjustable with tilt and rotate.
https://www.monoprice.com/product?p_id=44894
Monoprice Desktop Freestanding Speaker Stands Pair Adjustable
Product # 44894 UPC # 889028193655
Adjust Height from 10.4" to 15.9"
Fits most Medium/Large Bookshelf Studio Monitor Speakers, 9.1" x 9.1" (231 mm x 231 mm)
Ultimate Sound Improvement‑Tilt 30° Up/Down
360° Rotation Range
Dimensions 9.4" x 9.4" x 15.9" (240 mm x 240 mm x 405 mm)
Weight Capacity 33 lbs (14.69 kg)
Boris Badinov
The Humorist
Georgia, USA
What speakers do you have? Would something like this work?
Link
Yorkshire Mouth
Yorkshire Mouth
360° Rotation Range
No, my desk isn't big enough.
I could have bought a wider desk and put desk stands on it, but I went for a narrower desk and speakers on floor stands.
Doodski
I always used books for desktop speaker stands. They are adjustable, in plentiful supply and they make for a nice appearance with multicolored arrangements and tapered pillars if that's your thing too. :D
thewas
I just use these cheap best sellers from Thomann since almost 10 years for my desktop setup
Penelinfi
I guess you'll need to find adjustable stands, or use an object to raise the speakers up,
Or tilt the speakers up
Or there will soon be a larger desk (or maybe just extend that glass part using wood panel instead? )
Schlippwhip68
Essex, UK.
Roadworx
