I will not listen in a big voice, the power and spl is not a problem.It will be on my pc desk, for music, movie and games. Their specification is closed, what is the difference of sound and feeling? For my situation which do you prefer.
It is impossible to tell what you prefer as this is unlikely to coincide with my preferences.It will be on my pc desk, for music, movie and games. Their specification is closed, what is the difference of sound and feeling? For my situation which do you prefer.
Can we use dirac live or sonaworks to calibrate psi a17?I've owned those PSI's for years, great sounding speakers.
However, I'd prefer the Genelecs on my desk.
The most obvious reason is because of GLM to take care of the desk reflections.
I'll never use speakers without dsp correction anymore on my desks.
BTW: I'd also have a look at the new Neumann KH150's.
kh150 is a good monitor, but it is too big for the pc deskI've owned those PSI's for years, great sounding speakers.
OK, but the PSI isn't that much smaller.kh150 is a good monitor, but it is too big for the pc desk
PSI official site mentionsif you desire to have the induced latency induced, which would be always present in the PSI
right, so that's my misconception, wonders what the GLM filter will induce.PSI official site mentions
But the latency must be very low when monitoring recording, mixing or in postproduction. Our largest speaker has a latency of only 0.6 milliseconds, which suffices to align phase down to 150 Hz. This latency is the same as moving the listening position back by 20 cm as it will take sound 0.6 milliseconds to travel that distance.
While Genelec Extended linear phase adds 3,7 msec to already existing few msecs for DSP crossover.
For home consumer use case it does not matter, only for professional monitoring.
Do you like olives and does the OP like olives? If the answers are 2 x yes or 2 x no, then you can safely recommend speakers you like and he will like them too.It is impossible to tell what you prefer as this is unlikely to coincide with my preferences.
Nope. Utterly incorrect and impossible and your olive analogy is terribly flawed and oversimplistic for such a complex thing as sound. Plus there are many type of olives…. you wouldn’t believe.Do you like olives and does the OP like olives? If the answers are 2 x yes or 2 x no, then you can safely recommend speakers you like and he will like them too.
German or American?Nope. Utterly incorrect and impossible and your olive analogy is terribly flawed and oversimplistic for such a complex thing as sound. Plus there are many type of olives…. you wouldn’t believe.
Olives?German or American?
PSI A17 is +- 45 degrees from 300 Hz up.are PSI and Genelec The Ones equal in term of phase alignment/linearity
