Try waiting at the Brussels flixbus station for a few hours, your preference will changeWhen I'm outside I prefer to aware of my surroundings.
I’m not 100% sure about this Sony model (but I believe so), but my Bose QCIIs and the Plantronics Back Beat Pro 2 (that I also owned and liked and now my wife uses) are not exactly only “a Bluetooth product”. Unlike other Bluetooth headphones, they can work wired, connected through a 3.5mm Jack.(...)the wireless Sonys and presumably every other wireless headphone on the market sounds fairly bad (...) These bluetooth products (...)
Agree! Let’s not forget the moments when the Roomba decides to enter your roomAlso, while you don't *need* noise cancellation in a home environment... it maybe helps more than you think.
Sony ANC HPs are maybe kind ot average, but any amount of DSP & EQ trickery can work wonders if done properly, there's no reason why it wouldn't if THD &FR look correct, so DSP/EQ bashing is just snake oil.. The onboard DSP and EQ trickery you mention is not going to close the gap with even a $75 wired headphone run off a smartphone hp jack.
ANC is completely state of the art in quality terms. Why? Because if you manage to manufacture a low-THD driver and/or get it via feedbacking, the ANC itself pushes the noise floor in bass down, thus both preventing clipping (since less noise floor means lower needed bass level to get the same result -> more amp juice for peaks) AND causing unmasking of details which are lost in the noise floor; I think both arguments are absolutely easy to spot and trivial for anyone using properly implemented ANC headphones.Agree! Let’s not forget the moments when the Roomba decides to enter your room, or the furnace to kick in, or the garbage collection truck runs late...
Somebody make wireless headphone that has tidal mqa built in and phone is just a remote. It’s like streamer in your head. No more this bluetooth codec mess. Amazing that 4th generation product by Sony still sucks.
Do all noise cancelling headphones work this way or do some cancel everything including non-repetitive noises?
That's a common and oft-repeated belief, but not actually true.
How the noise changes over time (engine vs human voice) is irrelevant to the noise-cancelling process, it's only the frequency range that matters, since ANC is typically a minimum-phase system (meaning the ANC algorithm is able to react virtually in real-time, within less than one period (meaning "in phase") of the signal, which means it's not important how the frequency of the noise changes over time, since the ANC is able to correct for any change in real-time).
In other words:
Noise is being reduced by the same amount of Decibels, regardless of whether it's a human voice or a steady-state drone of similar frequency content.
So why can you still hear voices, while the train engine appears to be all but gone?
Because our brain is incredibly good at picking out voices.
I've touched the subject in a rather lengthy post about the limits of ANC
Now the question: Can we reach absolute silence as far as our hearing is concerned, a sound pressure level of 0 dB?
Is this possible with ANC headphones?
No, not at the moment. And not in the near future.
And here's a couple of reasons why:
For ANC to work you need microphones recording the noise on the outside of the earcup. This recording is then phase-inverted (every - becomes a + and vice versa) and played back by the drivers of the headphone. Sound that enters the headphone (and subsequently your ear) is cancelled out because it is mixed with its own inverse: Plus and Minus equal zero. All this is done in real-time, which means that as far as the ANC is concerned, there is no difference between speech and the constant drone of an airplane engine. The "anti-sound" is not synthesized, it is simply the real-time recording with its polarity inverted with filters added.
In reality there are a few factors coming into play that make matters more difficult:
Higher-end ANC headphones use not only microphones on the outside of the earcup but also one microphone on the inside of the microphone (in a feedback circuit). The aim is to measure the noise level inside of the earcup. Quite challenging because you need to distinguish noise from the music that you want to be playing.
- the noise that enters the earcup is different from the noise recorded by the microphones - because the earcup itself will filter a lot of high frequencies from the noise. This means that the output of the microphones needs to be filtered accordingly, otherwise we would experience amplification instead of cancellation - the opposite of what we want.
- the noise entering the earcup does not hit your eardrum at the same time as it is recorded by the microphone, because sound takes a finite amount of time to travel from the outside of the earcup to your ear. ~343 meters per second is fast but not infinitely fast. This means that the waveforms of the noise and of the recording will not overlap perfectly. This is no problem at low frequencies but becomes problematic above about 1 kHz, where the two waves will lose coherency.
- the microphones are not perfect. Since we typically use some of the smallest microphones available they inherently have a relatively high self-noise compared to high-performance microphones like you use in recording studios or measurement setups. The microphones also require signal conditioning (amplification) which involves active electronics that also have some level of self-noise due to their small size. This system-noise is of course different from the outside noise, which means that it will not be part of the cancelling and will be audible. It's possible to reduce it with good circuit design but it's especially noticeable on cheaper ANC headphones, where turning on the ANC mainly introduces hiss.
- The drivers are not perfect. Inherent distortion (THD, IMD) still exist on drivers, and while it is much less of a problem than it was just a few decades ago, it still limits the performance of ANC since it introduces further uncorrelated noise to the system.
- Even if we somehow managed to completely make the ear airtight and shut it off from the outside world (e.g. by pouring concrete into the ear canal) there would still be sound travelling along your bones as solid-borne noise. I've actually talked to a manufacturer of hearing protection and hearing aids about this, and they said that by filling your ears with concrete (or a similar substance of high density) you would be able to reduce outside noise by about 43 dB. Hence I assume that's about the maximum that can be done with passive isolation.
Plus it introduces another microphone with self-noise to the system (see 3.)
No noise-cancelling headphones you buy work [by canceling "repetitive" noises], including this one.
You can equalize the curve, but you can't equalize in more ANC.No noise-cancelling headphones you buy work this way, including this one. Such misinformation is just based on 'lay intuition' and a lack of understanding of how ANC headphones actually work. As Oratory (an acoustic engineer) explains:
Relevant excerpt from that lengthy post he mentions:
Factors 1 and 2 are why ANC headphones usually don't cancel noise above ~1kHz well and so these frequencies will often still be heard (less auditory masking by bass noise due to the ANC working better down there will also make this higher frequency noise relatively more audible). In fact, as Oratory says, these two factors sometimes do result in the ANC amplifying noise at these mid to high frequencies relative to passive mode, as is the case with these Sony XM4's between ~600 Hz and 3 kHz (Rtings' measurements):
This is relatively poor at these mid frequencies, although these issues are not uncommon among ANC headphones - if you want good noise isolation in the midrange, I'd say passive isolation from custom-molded IEMs would actually be a better choice in this regard.
The previous XM3 model actually does better in the midrange (and just a bit worse in the sub-bass):
As does the XM2 in the midrange (although significantly worse in the bass, particularly upper bass):
In terms of frequency response however, the latter seems the most balanced overall with a predicted preference rating as calculated by AutoEQ of 72/100, slope -0.53 (0 being neutral), the XM3 the worst (rating of just 33, slope -2.09), and the XM4 mediocre (rating 42, slope -1.63):
Unfortunately with these Sony models then it looks like you have to choose between the best overall ANC (XM3) or the best frequency response (XM2), or the relative jack of both trades (XM4).
So why do people continue to perpetuate the mis-truth that ANC doesn't work for non-repetetive noise then? Partly it's just blind regurgitation of oft-repeated audiophool 'wisdom' without critically thinking about the issue, as is the case with many other audio myths. And partly I suspect it's the common fallacy of conflating correlation with causation, without understanding the actual casual processes involved in the technology. Because our ears are most sensitive around the frequencies ANC stops working well, and environmental noises at these frequencies tend to be less repetitive (e.g. speech, which as Oratory said our brains are even more attentive to), compared to noise at lower frequencies (e.g. aircraft drone), some people incorrectly draw a causal link between 'non-repetetive noise' and 'ANC not working', when in fact the actual causal factor influencing the latter is 'high-frequency noise', and the co-incidence with the former is merely one of correlation. I suspect an additional factor at play here is auditory sensory gating, in which the brain has been measured as lowering its attention to repeated identical auditory signals (interestingly a function which is impaired in schizophrenic patients). Basically, we automatically filter out to a degree repetitive environmental noise, and so we are naturally relatively more attentive to non-repetetive noise in our environment, which makes perfect sense evolutionarily, but as with many of our atavistic traits, doesn't gel too well with modern, first-world problems such as wanting to listen to music through headphones in peace in a noisy coffee shop full of plates and cutlery clattering, chatter, laughter and crying babies. Thanks evolution!
To sum it up the wireless Sonys and presumably every other wireless headphone on the market sounds fairly bad compared to any budget priced wired headphone. The onboard DSP and EQ trickery you mention is not going to close the gap with even a $75 wired headphone run off a smartphone hp jack. I have a pair of wireless Sonys and I had to acclimate myself to their mediocrity, distortion and unnatural sound signature in order to reap the benefits of wireless convenience. These bluetooth products are for people that want to listen to music while taking a dump or making an omelet in the kitchen.
Only 1 iPhone app supports PEQ, as far as I know....Can anyone tell me if this is an convenient IOS app to get the same kind of EQ when the XM3 is connected to my iphone?
I don't think anyone buying these headphones intends to use them via cable. They are Bluetooth headphones and that's how 99% of people are using them. The convenience is tremendous and worth sacrificing a bit of quality (if it's only a bit). No DACs, no headamps, no cables, just Bluetooth, and freedom.
Therefore, having a review focusing on a cable connection is pointless. This is not all about. The cordless, dac-less, headamp-less setup is the future, and that's obvious. It's not on the same level yet but it will be; it's just a matter of time.
Me too. PleaseI own a XM3 which I found very useful when traveling and waiting for hours in various airports around the globe. Following the nice review of the XM4 from Amir, I used APO+PEACE to eq it when connected to my PC. I am really convinced by the improvement on its sound quality when EQed using the Oratory 1990 parameters. Can anyone tell me if this is an convenient IOS app to get the same kind of EQ when the XM3 is connected to my iphone?
