staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,032
- Likes
- 26,379
I got them directly from oratory1990 on Discord.Where did you get these from?
Sony have implemented an interesting new guided EQ feature in the app (beta) which takes you through several screens allowing you to adjust settings 'blind' on whatever you have playing and spitting out an EQ at the end. Quite a good idea although I think it would be helpful at each stage to give some clue as to what you're assessing (e.g. treble) so you can focus on that aspect.
I’d like to send you my skull candy anc2’s. Is there a thread you can link me too that tells me how to do that?I need to test the Bose and Beats to see how bad they are. Hopefully someone will send them in.
Use Wavelet slider to correct linear for personal transparency mostly 63% depending how music is masterd great feature in Wavelet.I use them with wavelet on andorid to have flat response and let me tell you this are 10/10 headphones. Sound comfy, not tiring ears, a bit soft. And ANC is gold. Especially during long train rides. And battery is easily of the greatest also, I can use them for 2 weeks easily. One downside can be mic, works only in rooms, outside is hard to talk to someone. I have them over 2 years already. INSTALL WAVELET RIGHT NOW, this makes them 100x better
they released a recent update, maybe it's worth checking?Great headphones for mobile use, especially on airplane, subway, etc.
In Moscow they help me a lot to reduce the noise level in the subway while still being able to hear music.
I think they sound good for their class.
They conveniently fold up without taking up a lot of space. They hold a long charge.
I have been using them for about 5 years. Unfortunately not without problems. ANC sometimes makes a very strong "beeping" noise for the first 3-5 seconds when turned on. (started around about 3 years after purchase)
You can google “WH-1000XM4 screeching”.
It goes away, but it is an inconvenience, I have not been able to "cure" it.
Firmware?they released a recent update, maybe it's worth checking?
I have these too and sadly my earpads dry rotted and fell apart. The replacement pads I've found all stink, so I've moved on to using the XM4 exclusively, which are pretty good with Wavelet using Amir's EQ.By far, and I mean by far, best tuned NC headphones Sony made were WH-H900n turned on with NC off (NC ruins the sound). Pretty depressing how they went under the radar but oh well.
Yeah, the aftermarket earpads are terrible sound wise. I spent a lot (A LOT) of time playing with different combinations and the only way to get aftermarket ones sounding remotely close to the original (Id say 90%, but still noticeable) was to dissasemble the pad, reuse original plastic base and mesh fabric while using the aftermarket sponge and leather part but tightening it by A LOT (original earpads are about 18mm thick, aftermarket ones are about 22 and my modified are just 14mm). Now, general presentation is VERY similar but there is a slight treble peak and lack of definiton in the mids which is a result of inferior PU film (grey creased thing on the inside that flakes off) and leather.I have these too and sadly my earpads dry rotted and fell apart. The replacement pads I've found all stink, so I've moved on to using the XM4 exclusively, which are pretty good with Wavelet using Amir's EQ.
Same with mine, I use a usb c/c charger. Probably my best audio purchase honestly, those things are great.My XM4 shows charging at 2 W (5 V @ 0.4 A) with my USB-C charger.
Probably because Sony didn't want to pay for a PD compatible charging chip. There are many wireless headphones like this; but I wouldn't expect to see such behavior from Sony.... its more of a cheaper brand thing, since they tried to pinch pennies and use older MicroUSB era charging chips electrically wired to USB-C.One thing about these (XM3 and XM4) is that they only will charge on a USB-A charger even though they have a USB-C socket. That's why the Sony cable is USB-A to USB-C.
Kind of pathetic IMHO.
Qualcomm devices all support PD. PD was never a rival to QC because QC is a quick charge platform that was on USB-A and it also works with USB-C. So there would be no reason that USB-C PD wouldn't work.Lol MX 4 and 3 use Qualcomm BT SoC and there for don't support rival PD over QC. Nothing to do with Sony what so ever. MX 5 ended this practice so it would probably work with PD but you don't have Apt X codec anymore (lose less and low latency where useful while HD whosent bad).
