Feelas
- Joined
- Nov 20, 2020
- Messages
- 390
- Likes
- 316
Herr Mann?I thought it was Herman.
Guess not, according to that chart (which I now see is missing some percentage ranges, so take it with a grain of salt). Because it's a Harman headphone we can guess that it was designed with their target curve in mind, but it's not a perfect match. The preference score and charts do show that it is reasonably close compared to most other headphones.Oh, good. Since the K371 scored an 89, it is not in the excellent range.
There is no binary yes/no for "does it conform or not." The preference score is an approximation of conformity. The 7506 conforms more than headphones with a lower preference score. Also, I'm not familiar enough with the formula to know how the weighting works. Maybe it's a lot easier to reach a score of 80 than it is to reach 90, based on the fact that the rankings only show 9 headphones in the 90+ range.So I guess anything in the '80s is considered conforming to HTR? 7506 got an 80. So it must conform to???
But that's exactly what the preference rating reveals. If I assign you a grade based on how well you performed to my chosen standard, how is that not an indication of conformity?So with your definition of "conform," saying a headphone conforms is a meaningless descriptor.
I find my understanding of "conforms" more useful. It encourages conversation about which headphone is closest to conforming, rather than painting a bunch of headphones with the same brush.
Overall I can't see a good reason to recommend the Sony MDR-7506. It gets some important things right (mid-range tonality) but so many things wrong that I just can't tell anyone to go and get one. If you have it, please give the above EQ a test and report what you think.
Who is using it that way? Which headphones with 90+ preference scores have frequency responses that don't correlate to the Harman target?I think you completely lost track that my main point of contention is about using the word "conforms" to describe anything that kind of looks like the HTR curve.
If you go by a strict definition, nothing conforms to the curve because no headphones score 100. Where does that get us?
If you're implying that the designer's intent to hit a target curve should be taken into account, it won't matter because the results will show their success or failure anyway.
I've been following this conversation from the beginning. Here's your first post:Thanks for admitting that you jumped in the middle of the conversation without knowing what the point of contention was.
You are welcome to retrace the flow and see what I said.
So what? All headphones can benefit from EQ to get closer to the target curve. Your initial statement here is not specific to the K371 or any other headphone yet measured.That's not accurate, based upon measurements I have seen. The K371 are very close to HTR, but do benefit from EQ to conform to it. Here is a graph from oratory comparing them to HTR
I got my pair years ago on the advice of sound engineers who used them for mobile monitoring. There was no promise they would sound 'good!'
And the earpieces flake.
My read of the graphs is that if you're not playing low frequencies loud then these should sounds pretty good so it's easy to think of engineering tasks where they should work well.I got my pair years ago on the advice of sound engineers who used them for mobile monitoring. There was no promise they would sound 'good!'
Only if you don't replace them because something else broke first. In studio use all phones wear out pretty quick. Maybe there are some in higher price classes that are engineered for durability but these are under $100.And the earpieces flake.
Even moreso, theoretically you could use a big low shelf to force these not to play under 50Hz where it doesn't matter, but there's a risk of it being present.My read of the graphs is that if you're not playing low frequencies loud then these should sounds pretty good so it's easy to think of engineering tasks where they should work well.
