Is there something wrong with your SU-9 and you are expecting a firmware update?
Thank you for the info. There is nothing wrong with my SU-9. I had to update my SU-8 on arrival, just wanted to be sure.Is there something wrong with your SU-9 and you are expecting a firmware update?
Check SMSL's HP support to find out if there is a firmware update at any time.
The latest USB firmware is Ver 2.06. Your SU-9 is up to date.
Good question but I think it's just the flat part that you should look at. Right @amirm ? Or is the fluctuation at the end more than an artifact.What's the meaning of the fluctuating output impedance at high frequencies? I suppose it affects frequency response. Is it a common property of DACs?
This is my question as well. I’m considering this upgrade because my hypex ams like XLR but I’m not sure what will be gained. More volume possibly?Is there an audible difference from say, a D50s? About 10dB SINAD difference, and I guess MQA, for $180 :/
someone can confirm this?
"I did notice coil whine coming from my unit. I tested from multiple different power outlets on different circuits with the same result. This isn’t something I’ve experienced from the vast majority of other sources I’ve tested so I would not think it due to my particular setup. Noise isn’t introduced into the actual sound output, but the whine coming from the device itself is irksome especially when listening to open-back headphones or earbuds and not what I would expect from a high-end source like this. SMSL engineers also confirmed this is normal behaviour of the switching power supply, but that the noise on my unit is at the higher end of normal." -- https://theheadphonelist.com/smsl-su-9-review-epiphany/
This is exactly what I came to this thread to find out. Haha. Give me an answer!I would say they are neck-and-neck. SU-9 has the best multitone..
Are you using tidal exclusive mode? Max volume? The stream needs to be in tact if you want it to be recognised as MQA.Hello. I just got this and I don't think the MQA feature is working correctly. This is supposedly a decoder which can do the 3rd unfold, but the SU-9 only displays 44.1 when I am playing MASTER MQA files on Tidal through PC.
There is a distinct lack of coil whine from my SU-9. My power supply is UK type.Hmmm, this is a very interesting post, I'm a bit surprised nobody is reacting or answering? I would also like to hear a comment from somebody owning the SU-9 about the coil whine.
I am now using Exclusive Mode and Max Volume. The DAC now says "MQA" but it also says "44.1kHz." Shouldn't it say 176.4 or 352.8? EDIT: And NO COIL WHINE!
