AudioSceptic
I'm confused. If you are asking this, you must be considering buying the product. If you already own it, you will know the answer.Still not answering the question though
There is no PLL setting. The most inexpensive balanced DAC with this feature is the SMSL C200, to my knowledge.does anybody know if this DAC has the PLL setting so that "lower quality SPDIF/optical" can be used?
thank youThere is no PLL setting. The most inexpensive balanced DAC with this feature is the SMSL C200, to my knowledge.
There's an option in the menu to change these, just have a poke around. Best to listen for yourself rather than have comments from others prejudice what you think.The manual says there are 9 settings for different sound colors (not dac filters related) that changes the 2nd and 3rd harmonics, has anyone tried that?
How do I change those settings? Thanks.
I just used this as a straight DAC. I could not hear any difference what so ever with the setting. Leave them as not used.The manual says there are 9 settings for different sound colors (not dac filters related) that changes the 2nd and 3rd harmonics, has anyone tried that?
Thank you, the menu isn't easy to navigate but found it eventually and then I realized (when I saw that part of the menu and the settings) I had actually tried those settings before. Just haven't used the SU-8 for ages because I have so many dacs; and when I read the manual it does not show which menu page it is in, it just says it has the feature.There's an option in the menu to change these, just have a poke around. Best to listen for yourself rather than have comments from others prejudice what you think.
I haven't used mine for ages either. I really should have sold it by now but I am useless at getting round to such things!Thank you, the menu isn't easy to navigate but found it eventually and then I realized (when I saw that part of the menu and the settings) I had actually tried those settings before. Just haven't used the SU-8 for ages because I have so many dacs; and when I read the manual it does not show which menu page it is in, it just says it has the feature.
Solution:Has anyone solved the problem with SU-8 not connected\visible via USB with "Unlock" status instead of sample rate?
Best sinad is at max volume.Just a quick question.
When the SMSL is connected to the int. amplifier (used only as a DAC), should the volume be set to max or maybe a little less?
As far as I can see SMSL has no fixed volume output.
Thank you
Get the SU-8 only if you need XLR outputs and remote controlHello community!
Does it still going strong in 20024? Wanna upgrade my old SMSL M3, that i use with Android phone to listen flacs via vintage amp and speakers, also through small Xduoo 602 HP amp.
Looking at this SMSL SU-8 and SU-1. Will be there a noticeable difference / worthy upgrade? And which one is definitely a better choice?
