arrow0309
96db spl rated these DT 880 and I'm keeping them in gain 3 with my L30 II.Low? Certainly not in power, because this headphone is spec'd at 100 mW power handling capability. Most headphones are spec'd lower.
At a nominal SPL of 96 dB at 1 mW the max "safe" (for the headphones, not your hearing!) SPL is 116 dB. Turn up the volume beyond that point (100 mW or 116 dB SPL) and you risk permanently damaging the drivers anyway.
As usual power is not the issue. The 32 ohm version is much harder to drive, for example, as it needs 3x the current for the same SPL.
People keep confusing power with lack of gain, which typically is the actual issue.
In my listening level spreadsheet I calculated that in the worst case with completely uncompressed high dynamic range classical music you only need ~24 mW for "safe" (depending on your listening time) average listening levels. And this is not continuous power but will only be required in very rare peaks in the music.
If you listen to modern pop/rock then you only need ~1 mW for the average level.
The Amiron Home are fine in gain 2 (over 1 o'clock).
I only listen at high volume sometimes but still.
@Jimbob54 you're right about the K7 (damm publicity specs).
I think I'm keeping my (last) D10s / L30 ii cheap combo.
Although one of these mkiii should suffice in power as well and they're sexy that's for sure.
