SMSL D-6s Balanced DAC Review
Rate this DAC:
    Votes: 10 2.3%
    Votes: 6 1.4%
    Votes: 28 6.6%
    Votes: 382 89.7%
Assume also that DAC device measurements are performed under artificially isolated conditions. The intention is that only the device of interest is measured.
I'm really pleased to watch this technically very profound discussion. :)
I recently measured a Topping E50 from a friend of mine. I am using a relatively cheap ADC and I did see a lot of lines in the spectrum well above the noise floor, that are not harmonics. So I connected a linear regulated lab-power supply instead of the 5V SMPS. All of these lines have disappeared leaving me with the distortion of the E50 and (clearly dominating the picture) the distortion of my cheap ADC.
This measurement was performed single-ended and without USB- isolation - name it "real world".
-> I agree, it is not very likely we obtain the ca. 22bits of this DAC in real life.
Of course, there's not much energy in the "noise" the SMPS introduces, so again it's questionable if this is audible.
I always like to spend a few weeks listening to a new DAC before taking measurements so that my subjective impressions are not swayed by objective data. After playing with the seven filter settings, I settled on FL3 as sounding the most "right" to my ears. I finally got around to taking some measurements today to see what's what.
TL; DR - avoid filters FL1 and FL6 because of distortion at ~14 kHz and excessive attenuation in the highs. FL3 and FL7 are the most useful. Choose FL3 for most listening, but FL7 may be beneficial with some music, depending on your tastes.
F2 is the default filter. Here's what I see for Amplitude and Impulse response, and Distortion.
You'll have to mentally compensate for the inverted horseshoe shared amplitude response. I don't have a great way to compensate for the ADC response of my Focusrite Scarlett 2i2 audio interface, and the vertical scale is only 1 dB, so pretend that this is flat. :)
Impulse response shows extended pre-ringing ripples and exaggerated post-ringing with this filter. No obvious issues with distortion.
With the FL1 and FL6 filters, I'm seeing early attenuation in the high frequencies and a sharp increase in 2nd order distortion at around 14 kHz:
I'm not sure how audible this is, but I would avoid FL1 and FL6 for this reason.
After looking at response of all seven filters, FL3 and FL7 are the most useful. FL3 has a little more pre-ringing than I would like, but it's under 5% from -500 to -140 microseconds and zero before -500 microseconds.
In contrast, FL7 has more extended pre-ringing ripples, although very low in level. It also has a much longer and more exaggerated post-ringing, which can be a useful effect with some music.
The default FL2 and FL7 have virtually identical amplitude and impulse response, but FL7 had lower distortion in my measurements. YMMV.
I may do some sampling rate comparisons to see if there's a rate that works best with the D-6s. So far, I've not seen much difference, though. In particular, impulse response for 44.1 and 48 kHz look virtually identical. That's not been the case with all ESS DACs I've measured.
So, after these measurements, do you like it or not? Or do you think it's worth buying one?
I'm totally hooked on this DAC, even before measurements. And, if the measurements were disappointing, I'd still be happy with the sound. ;-)
I've been enjoying the D-6s so much, I'll probably buy another one for my other system (to replace my Gustard X18). The D-6s is the best sounding DAC I've tried so far, including the much more expensive Benchmark DAC3 B and Topping D90SE.
Short answer: Yes
Short answer: Yes
Thanks.
Have you tested it via optical or coaxial? Is the volume output via these adequate?
There were reports about other SMSL DACs, that there was low volume via spdif, compared to USB...
Thanks.
I have. Identical output levels and response via both COAX and TOSLINK S/PDIF. For these, I'm using a WiiM Pro streamer, as mentioned above. The WiiM Pro and the D-6s make an excellent pair if you don't care deeply about DSD or PCM above 192 kHz.
That's great news. Thanks
Wanna use it with Sony UBP-X800M2 Bluray/SACD + my Dynabook Ryzen5 laptop/ LG V40 phone(bit perfect).
I use FLAC mostly 16/44.1 up to 24/96. Nothing too fancy...
Oh! I forgot the Sony mds-je770 md deck. :);)
You'll love it. Sadly, looks like the $30 off sale is over on apos.audio, but price/performance is still there in spades at $199
Short answer: Yes
I had the DL200 and felt the same about it. I think the 9039 chip is dandy. Sadly, my DL200 began popping when turned on, and it was getting louder over time. I wasn't liking this development, particularly with it hooked up to an amp that could send at least 240 watts to each speaker. Thankfully I had two days left for an amazon return and I ordered a DO300 as a replacement. To my ears it sounds dreamy good too. But I am a bit concerned about smsl durability and going to stick with Amazon only for these purchases. Hopefully the D-6s will show up there eventually as I would like one.
Off topic: where can I find the explanation of the different colors of MQA?
Green: This is used by software or hardware that can perform the first MQA unfold (MQA Core). It tells you that even though the MQA file being decoded can be authenticated, the recording engineer hasn’t declared the track to be the definitive version of the recording.
Blue: This is used by software or hardware that can perform the first MQA unfold (MQA Core). It indicates an MQA Studio track, which in addition to being authenticated, is also considered the definitive version of the recording. According to Bob Stuart, “The sound you are hearing is exactly as played in the studio when the music was completed.”
Magenta: This is used by an MQA hardware renderer (or a full decoder) when these devices receive an MQA Core stream from an app or another hardware device that has performed the first unfold. It indicates that the stream has been correctly encoded as an MQA file, but it cannot authenticate it or tell you if it is an MQA Studio track.
My D70S isn't that detailed. It just says MQA with a little logo on the screen. The SMSL SU-8S had the little lights.
Why are you attempting to use dying MQA? No other possibility?
@dsnyder0cnn is there any specific reason to say this " if you don't care deeply about DSD or PCM above 192 kHz. "
I'm looking for a DAC to pair with my WiiM PRO and considering this DAC but your recommendation is bit disturbing as I have DSD files too and love to listen it
TIA
TIA
It's because the WiiM does not support DSD or PCM >192kHz.
Edit: Nvm, it does support >192kHz and DSD.
Reactions: SiR
Welcome your response @staticV3
What if I use DSD files from Laptop connected trough USB to the DAC ?
Then it will not be an issue isn't !!
TIA
TIA
The D-6s will play DSD via USB just fine.
Streaming DSD from a WiiM Pro to the D-6s via Coax may be possible as well.
Edit: the WiiM Pro page isn't super clear about that. The Pro Plus page does claim up to 32/768 and DSD512 via Coax though.
I read it and it seems really strange to me as a statement.
The manual says differently… :rolleyes:
We should ask them. ;)
TIA
Although the D-6s supports DSD64 over DoP perfectly well via its S/PDIF inputs (both TOSLINK and COAX), the WiiM Pro will not output DSD64 over DoP.
