SMSL DO200 Pro arrived today: initial impressions review.
Dunring
Florida
Just got a Fedex from Aoshida-US and it had the new SMSL DO200 Pro. My daily driver is the SMSL D-6s, so this sounds identical, but has more inputs and the nice IPS screen. The filters are named different, and no color options like many of their other DACs.
There's:
Fast+Latency
Fast+PHComp
Slow+Latency
Slow+PHComp
Non-Sampling
It's got 12 CS43131 chips and 5.2v output (I have a Topping D30Pro with 4 chips, and it looks like put twelve in this just to show them up:). I'm testing it with a Topping A90D Discrete and have an A70Pro to try it with later. It's longer than the A90D and not as wide, but I think it might fit better under the A70Pro. I have an SMSL SP400/M400 and will see, it looks like that shape and size if you get one for a stack. To be honest the much cheaper SMSL DL200 is a lot more versatile since any size amplifier will fit on top of it (except some Gustard stuff which are usually huge). Functionally there's no tick sound when switching bit rates like the DL200 and D-6S. The volume wheel is smooth and remote is infrared and range is good. I'm using the default filter since the 12 chip design doesn't have measurements yet.
I've got a DO400, and CO300EX and as a DAC there's just no difference. If you have a music library of different bit rates, you'll like the silence when switching. The Bluetooth 5.1 works well, I have a 5.1 adapter on the PC just for testing. The Google Pixel has LDAC and it's fine too, even bringing the phone into the other room to get it as far away as possible.
I'm sure this well measure well, but which filter is best remains to be seen (heard). I just don't see how Topping is going to be able to get $900 for the new D90 III with the same performance for less than half the price. Judy at Aoshida said the MSRP for these is $549, but I got this one for $399. The Summer Sale on Aliexpress is coming up, so if you wait and rack up coins in the meantime, then use a cashback card to double the warranty, and the coupons for the sale stacked too, you can bring the price way down. To give an idea, on the last Summer Sale I got a Topping A70Pro for $350 and a DL200 for $133 after doing those things. If you have a tax certificate for business, register it at Alibaba and then you'll be exempt at Aliexpress as well.
Overall, if you need this form factor and connectivity, it's a really nice DAC. The lack of color options is strange at this price point though. I'm going go play Destiny 2 as an excuse for "further research" with it. Just check dimensions if you want to run a stack because the length and width aren't that compatible with Topping stuff, or many of their other products. I had the H300 that SMSL took to a previous Can-Jam and that would fit nicely under it. The bottom center runs really hot, so a vented monitor riser is highly recommended on that. The DO200 Pro DAC runs cool as you'd expect (unlike the Gustard X26Pro with two 9038Pro chips in current mode, that will keep your cat warm). Sorry I forgot to take the plastic film off in the photo :)
The SMSL DO200 Pro will almost certainly perform and measure worse than the SMSL D-6s. It will also be a worse value proposition.
What is the "job to be done" of the swarm of 12x CS43131's in the SMSL DO200 Pro, apart from fooling gullible consumers?
Hello, please don't make such predictions based on tea leaves, let the experts evaluate it, it is an interesting project and it may turn out to be exceptionally good.
Thanks a lot for the first report Dunring, I was also interested in this dac and it would certainly be interesting to compare it against the topping D70pro octo which has 8xCS43192. I look forward to further impressions and independent measurements.
Well, the DO200pro arrived yesterday and my first impressions are more than excellent. Filter No. 2 and 3 (fast+Ph comp - slow+latency) worked best for me, and it looks like it will probably replace the E70 in my main set. Later, when I have all my new dacs at home, I will find time to measure and listening tests and compare everything.DO200pro xlr Rch.pngRCA Rch.png
About its HDMI in, does it take I2s standards ? Or is it different? Would it be possible to have its pinout scheme somewhere? Where could we find any measurements on this dac?
The DO200 Pro's HDMI input only accepts HDMI ARC signals, like from a TV or AVR.
i2s is not supported.
Measurements can be found on the bottom of this page:
Damn this looks neat.
How do you feel about its sound?
I hesitate between this one and Topping D 70 pro octo.
I had high hopes for the SMSL DO200 Pro which has 12 obviously inexpensive Cirrus Logic DAC ICs in it, it did not sound good - just glassy bright sound that was fatiguing and made me want to stop listening. Both Tosklink and Coaxial inputs were tried, and USB. I own the SMSL SU-9 DAC with MQA as well, and that DAC sounds incredible, very pleasant/musical with loads of detail. The DO200 did seem perfectly functional and everything worked, I can only assume that there was nothing wrong with the unit. The tonal balance just didn't jive with my ears/system at all.
Interesting, it sounded different for me, just like in the review in #9
... very natural slightly laidback side, sound with soft delicate highs. I am using RCA output.
SMSL DO200pro new firmware found:
Review your audio chain carefully, the thing mess up with the sound output are just few: speakers/headphones/amplifier, cable should not have any impact, while DAC I can agree slight difference with the amp matching taking into considerations. Also I confirmed that TV USB vs optical decoding differently a lot, especially the bass, and optical the best sound quality for TV.
The advantage of paralleling DACs is well known, because noise and THD might be reduced and resolution increased (depending on the number of parallel DACs).
Economically their is a limit where this plays a relevant role, because otherwise the number of DACs might "explode" to be much higher for a small additional advantage...
Probably one of the reasons, why some measurements of the DAC are a bit better than the data from the data sheet would be expected.
If this might lead to a higher "SQ" has still to be proven, because individual preferences and "taste" dictate the outcome for each user.
That the "remaining" audio-chain will have a major impact on this is to be expected as always.
