Roland68
Actually, you are wrong on all 3 points.Not to bring this topick back up but there are some significant differences between the SMSL DO300EX and SMSL D400 Pro in architecture.
The D400 Pro is using a "CK-03 clock" processing Circuit to reduce clock jitter where the DO300EX does not, well I can't find any of that on the site of SMSL-audio.com.
For example the gustard A26 is using a similar technology with their "K2 clock" and this is their explenation: "K2 Clock In order to provide an accurate clock signal, the A26 features the ultra-low noise K2 module. This ensures that the DAC is able to achieve a very low jitter level for the most transparent sound possible."
Also the D400 Pro is using 5 peices of ""high-end"" dual op amps where the the SMSL DO300EX does not, or I can't find any info on their website about this.
The SMSL DO300EX does have a headphone amplifier though where the D400 pro does not.
Edit: Another difference I found is in the power supply of the DAC's. The DO300EX is using a single power supply where the D400 Pro is using a dual one. Also seems like another type of ultra noise power supply system.
Not saying the D400 Pro sounds better or worse but it might sound different than the DO300EX, and it might sound closer to the Gustard A26 than the DO300EX does.
Haven't heard both this is just info I found on the website of smsl.
DO300EX has the "The new self-developed CK-03 clock processing circuit greatly reduces clock jitter" and "Use 5 high-end dual op amps and a large number of audiophile components", original text from the description on the SMSL homepage and I looked into it.
The DO400 Pro has two individual single voltage smps from which the +/- voltage is formed, the DO300EX has a direct smps with +/- voltage, technically there is no difference. These are standard power supplies by the way, nothing special.
I had both DACs here, and even on high-resolution systems I can't hear any difference between the two DACs, not even a hint.
The really big difference is in the housing, the DO300EX has a cheaper sheet steel housing, but that is not a disadvantage.
