I sometimes see reports of pop noise or the beginning of songs being cut off with recent SMSL DACs or amplifier products equipped with DACs.My D-6s arrived this past Friday. After trying a few filter settings, I've settled on F3. It seems to have the best balanced of extension and attenuation. Currently paired with a WiiM Pro. Obviously, I've connected an amplifier since taking this photo.
They do. Sort-of. It's called the SMSL SU-1. ;-)I wished Smsl offered that model without these somewhat exotic balanced outputs to get the price down a little; it would make a great competitor to the Topping E30II.
Seems really slow to get to Amazon US as well. I bought a DL200 while waiting but want a D-6S as well.Why doesn't the product appear on the manufacturer's website yet?
I have. my reply was somewhat tongue-in-cheek.You haven't really looked at the specifications and components, have you?
That's a completely different product.
I guess if you really need Bluetooth, a display, remote control, selectable filters and DPLL, or have a strong preference for the ES9039Q2M over the AKM AK4493S DAC chip, the SU-1 is not a suitable replacement.
But both DACs support all of the same formats, including MQA CD (why that's a thing, I'll never understand) and probably sound almost identical. If you're not planning to use the DAC as a digital preamp and only need RCA outputs, the SU-1 will get the job done at less than half the cost.
There are all models but not this one.Seems really slow to get to Amazon US as well. I bought a DL200 while waiting but want a D-6S as well.
Haha. All fair points.For a moment I forgot where I am - of course they all sound the same! ...
But yeah, apart from the preamp thing, a remote, the dual chip design, a very different PSU setup, the bluetooth and balanced output options (I could well do without) ... wait...
Actually, the SU-1 is a terrible deal these days.
I got the Smsl C100 for 100€ shipped, and still wished the Topping E30 II and Topping E30 II Lite had sounded a little more mellow/forgiving on my system, after comparing those units.
Topping just gets the UI done far better.
But the SU-1, I can't imagine why anyone would buy that thing, it's not cheap enough to chose it over say a Topping E30 II Lite.
Some SMSL products are manufactured for specific distribution channels.Why doesn't the product appear on the manufacturer's website yet?
SMSL's SU-1 and Topping E30 ll are very inexpensive but excellent products that I also use regularly.For a moment I forgot where I am - of course they all sound the same! ...
Sure, but no one test DL200.If the DL200 indeed shows the measurements we expect (expectations based on comparing it with similar specs of other DACs/headphone amps) I think it has a chance to elevate SMSL to another level (like the Fosi did with the V3 in the amp section). The DL200 will, hopefully, end up being THE best price to performance DAC/headphone amp. Which really makes me wonder why the company did not send Amir a unit to measure LONG time ago.
According to the ESS datasheet, this DAC chip supports MQA (listed as an input on the schematic): https://www.esstech.com/wp-content/uploads/2023/03/ES9039Q2M_Datasheet_v0.1.3.pdf I think the MQA rendering will only be applied to files with an MQA flag, not sure how else it could work really.The D-6s is advertized to have MQA support. The actual DAC ES9039 does not have a MQA renderer according to the ESS overview (the ES9069 does).
Not that I really understand this feature - at least the marketing sounds suspicious to me - rather I'm scared the "decoding" might be activated inadvertently.
I'm also unclear which component in the D-6s does the MQA decoding if it's not the ES9039.
I did use HDCD in the past and this technique did make sense to me since - having the data 96/24 available - you can try to hide some information in the anyway dithered floor when you go down to 44.1/16. As far as I followed this topic, MQA got applied to material that was available in just 16 bit depth, such that the algorithm might "invent" some details. When even upsampling to higher fs this gets even more speculative.
Maybe my understanding of the MQA process is wrong. These thoughts only to make plausible why I'm cautious with the feature MQA.
Take this scenario:
I use foobar and I frequently sample up to 96/24 in order to have no sharp roll-off close to the actual audio band. Most of the actual material is ripped CD, so 44.1/16. Resampler usually is SOX which asfaik does not dither, but let's assume there even is dithering involved.
-> What would the SMSL D-6s do?
- Would it switch to MQA, modifying the roll-off to match the one required for the first MQA step? Or does this need a certain signature hidden in the data?
- In case it can get activated inadvertently, can I turn off this feature in the settings of the D-6s ?
I have not yet ordered a D-6s, so I cannot look into this by myself.
Any comments appreciated.
It may not. It is lossy compression which inadvertently reduces fidelity.properly applied, MQA may indeed improve sound quality
MQA decoding can be done either on the DAC chip, or on the XMOS USB bridge, which should be the case on the D-6s.I think that's a copy/paste. It's the signal path illustration that is identical to the figure in the ES9069 datasheet.
In the ES9039 datasheet MQA appears only in two figures
In the ES9069 datasheet MQA is described in more detail (37 occurrences of "MQA")
On the first page of the datatsheets MQA is in the feature list for the ES9069, not however in the one of ES9039
There is a nice overview: https://www.esstech.com/products-overview/digital-to-analog-converters/sabre-audiophile-dacs/
This raises the question: Does the D-6s indeed support MQA?
Since specs and pinout of the two chips are otherwise identical at first glance, it could as well be the D-6s is build around an ES9069, but marketing mentions the well known ES9039?
