Probably a stupid question - but I didn't find a specific measurement thread.Moved some posts to the measurements thread. Let's try and keep posts in review threads to the DUT please. Thanks
Here you go:Probably a stupid question - but I didn't find a specific measurement thread.
--> Can you provide me with a link?
www.audiosciencereview.com
I installed a D6S in a system that uses McIntosh tube amplifier and MartinLogal electostatic speakers. Excellent detail and imaging. I wasn't really sure I'd be able to hear the differences between DACs, but the D6S is really superb. Thanks.This is a review and detailed measurements of the SMSL D-6s balanced stereo DAC with Bluetooth support. It was sent to me by the company and costs US $199.
I was pleasantly surprised with the new industrial design which while minimalistic, manages to impress with its modern style. Love the matt diffuser in front of the white LEDs. And the elevated panel gives a distinct and dare I say, luxury feel. A remote control is provided which makes navigation very easy.
Very nice to have built-in power supply in such a small package:
SMSL D-6s DAC Measurements
Let's start with our usual dashboard with level adjusted to near 4 volts using XLR output first:
Distortion products are at -140 dB! Incredible. SINAD as a result is dominated by noise, and landing the D-6s in our top 20 chart of all DACs tested:
Even RCA output is impressive and fully audibly transparent:
Output can go to 5 volts using XLR giving us a bit more performance still:
As noted, SINAD is determined by noise since distortion component is so low:
For compatibility with stereophile magazine measurements, here is the 60 Hz performance:
Despite having a "punishing" load of 600 ohm as JA calls it there, D-6s sails with distortion at whopping -120 which I am confident bests anything stereophile has ever tested.
Back to our own tests, linearity is nailed:
As is jitter across all three interfaces:
Multitone performance makes the company proud:
We are some -135 dB in some of the frequency range!
EDIT: Forgot to post the IMD test:
Here are the usual filter and frequency response tests:
Using default F2 filter, we get excellent performance in our wideband THD+N with a slight rise at the upper end:
I pride myself in always finding something to complain about in a review but I have nothing for you here. Price is right. The look is right. And performance is top notch regardless of price. I always recommend balanced DACs and here is your chance to get one without any compromise.
I am happy to recommend the SMSL D-6s DAC.
Manufacturer Specifications:
- Inputs: USB, optical, coaxial, Bluetooth
- Outputs: RCA, XLR
- THD+N: 0.00006% (-123dB)
- Line output amplitude:
- XLR: 5Vrms
- RCA: 2.5Vrms (1.13Vrms)
- Output impedance: XLR: 100Ω
- Dynamic range:
- XLR: 129dB
- RCA: 126dB
- SNR:
- XLR: 129dB
- RCA: 126dB
- USB transmission: Asynchronization
- USB compatibility: Windows 7, 8, 8.1, 10, 11 (needs driver); Mac OS X 10.6 or later, Linux (driverless)
- Sampling rate and bit depth:
- USB:
- PCM: 44.1-768kHz (32bit)
- DSD: 2.8224-22.5792MHz (1bit)
- DoP: DOP256
- Optical/coaxial: 44.1-192kHz (24bit); DoP64
- Bluetooth version: 5.1
- Bluetooth codecs: SBC, AAC, aptX, aptX HD, LDAC
- Power consumption: <10W
- Standby power: <0.5W
- Size: 150x42x128.5mm (WxHxD)
- Weight: 1.57lbs (0.71kg)
As always, questions, comments, recommendations, etc. are welcome. Click here if you have some audio gear you want me to test.
you are able to hear the difference between them? What did you compare it with ?. I wasn't really sure I'd be able to hear the differences between DACs, but the D6S is really superb. Thanks.
SMSL Sanskrit 10th. Also a pretty good DAC. Aiyima T8. I use a Schiit Lyr3 on my desktop system. The D6S is at least as good.you are able to hear the difference between them? What did you compare it with ?
If you don’t hear any difference, are you claiming that all the 3 dacs you mentioned are sounding the same ? If yes, isn’t it just enough to buy the cheapest of the 3 and call it a day?SMSL Sanskrit 10th. Also a pretty good DAC. Aiyima T8. I use a Schiit Lyr3 on my desktop system. The D6S is at least as good.
Also replaced my Sanskrit 10th MKII with a D6s. Easily noticable differSMSL Sanskrit 10th. Also a pretty good DAC. Aiyima T8. I use a Schiit Lyr3 on my desktop system. The D6S is at least as good.
Not an unreasonable question. I think it has better imaging than the Sanskrit. In fact, I think it's less expensive than the Lyr but I think it may sound just a bit better (better imaging perhaps) and has options (e.g., optical, coax) that the Lyr does not offer. I still use the Lyr on my desktop system, where it serves very well, and I still use two Sanskrits, one also for my desktop and another for bedroom system. While I prefer the D6S, the Sanskrit it a good piece of gear.If you don’t hear any difference, are you claiming that all the 3 dacs you mentioned are sounding the same ? If yes, isn’t it just enough to buy the cheapest of the 3 and call it a day?
As per the science it cannot have better imaging. But I get your point.Not an unreasonable question. I think it has better imaging than the Sanskrit. In fact, I think it's less expensive than the Lyr but I think it may sound just a bit better (better imaging perhaps) and has options (e.g., optical, coax) that the Lyr does not offer. I still use the Lyr on my desktop system, where it serves very well, and I still use two Sanskrits, one also for my desktop and another for bedroom system. While I prefer the D6S, the Sanskrit it a good piece of gear.
I'd pay slightly more for daw-mda1 for more inputs. Easier to change settings as well, nicer displayI'm looking for a balanced DAC which can take SPDIF input. I'm planning to use it with Genelec 8030C speakers using balanced cables.
Which DAC would you recommend for this purpose? I'm thinking about SMSL D6, D6s or M300 SE. Are these equally good? Is there a major upgrade in the D6s vs the D6 version for my use case?
But I don't need more input I only want an SPDIF and an USB. SPDIF I'll use with a WiiM Mini and the USB with a computer possibly. And the MDA1 is double the price of the D6, from what I found. Is there anything else on these more expensive versions which might be worth it? So far I like the normal D6 as a middle ground.I'd pay slightly more for daw-mda1 for more inputs. Easier to change settings as well, nicer display
You probably can't hear the difference between s and non-s.
Pretty much any DAC will provide the same audio quality. To be certain select from the blue and green sections of the Sinad chart here.I'm looking for a balanced DAC which can take SPDIF input. I'm planning to use it with Genelec 8030C speakers using balanced cables.
Nope.Does the SMSL D-6s display screen show the sources bitrate data on it?
Only sample rate or codec when play bluetoothDoes the SMSL D-6s display screen show the sources bitrate data on it?
Unless you can hear the DAC's noise floor through your speakers (hiss with the D-6S plugged into the Amp, but gone with it plugged out), you are not losing any performance or resolution by using the D-6S' volume control, as in that case any potentially lost resolution was inaudible anyway.My question is about the volume control on the outputs. I have the D6s connected to a power amp and therefore use the volume control between -26 and -30 on the d6s,from the threads it would appear that I will be losing some performance and resolution from not this or I have read it wrongly. If so what would be the solution to correct this.
Such a poll would have to be accompanied by blind test results of each participant to have any meaning or value, which would be exceedingly unlikely.Also would be interested in a poll for which Filter is preferred for all the users.
