SMPS for Audio Applications
I have a two micro audio 600w smps 44v single ended..as I have changed amp modules and I don’t need them..looking to get $65 shipped
What model for two Eval 2 modules and what do you have to split the wiring from the SMPS to the two Eval 2 modules? Thanks.
SMPS1K-PFC is your best fit for Purifi, there are two options of splitting that DC output.
1- By using the 1 to 2 or 1 to 3 DC-SPLITTER PCB
2- Use the double output capacitors PCB ( This option will save you wiring) and neater.
You will need the extra capacitance at the SMPS output in all cases.
Some discount is applied to the SMPS1K-PFC with 30~45 days Lead time.
1 Day remaining
Thanks!
1 Day remaining
Thanks!
Hi,
I would be interested in a SMPS1K-PFC. Can I see a photo of the double output capacitor PCB and would you help me with any wiring questions I might have concerning your SMPS and the EVAL2 modules......I am a machinist, not an electronics person.
I have completed a EVAL1 amp using the hypex SMPS1200A400. Thanks.
John
Hi,
John
Here you go
You will get instant support any time you need it.
The SMPS is plug and play with Purifi.
Thanks
Ok....good, will you please PM me with all of the info I need to purchase one unit plus the capacitor PCB?
Thanks!
John
I can confirm that Sami's customer service and support is first class. I have no doubt he will go out of his way to help you get your build done.
Best wishes
J
Best wishes
J
Hi JayR,
Thanks man, I appreciate your input. :)
John
Thanks!
John
I can vouch for micro audio support...I bought 4 1kw and 6 600w smps..
Grab the last two SMPS1K-PFC at a special price!
Available in +-64VDC only Plug and Play for the Purifi Amplifier!
The deal includes:-
1- Full set of connectors
2- EMPTY extra capacitors PCB ( Single or Dual outputs)
3- All splitter PCBs needed to complete your installation
4- 1 Premade DC connector
Thanks!
SMPS500-CLA for class-A amplifiers with +-25VDC in idle & bias current up to 2A continuous per rail with 5V drop.
Excellent performance guaranteed with 39A peak output @ 16V drop only!
Wait for the upcoming!
Напишите пожалуйста габаритные размеры блока питания SMPS700-PFC.
Which one(s) are suitable for TPA325x amps, i.e. single rail up to ~50 VDC?
