- you say low EMI. How much lower than FCC class B or CISPR are these for conducted emissions and also for radiated emissions using a synthetic load? Do you have readily available plots?
I don't have any plot yet, to be honest, but it is low to the level it's not disturbing any sensitive device around it.
- You mentioned PFC function. At 240 VAC, and 50% power, what is the power factor and THD?
PFC function means a wide input voltage range from 110VAC up to 265VAC. and the 240VAC was written as a generic refrence.
I don't have any measures for THD yet, Power factor is 98% @ 110VAC & 99% at 240VAC.
PF @ 50% power is 98%
- most SMPS are not selectable these days but simply work over a wide input voltage range. What range do yours work over?
110VAC to 265VAC , and any range in between for example 178.7VAC
- what architecture do these power supplies use?
ZCS
- what is the minimum and maximum output switching frequency of what I assume is the second stage
65KHZ & maximum 71KHZ, FYI no synchronous rectifier
- have you done any work on regulatory approval. Looking at blow ups of pictures I have concerns about spacing for creepage and clearance
All of my work will go under CE approval at some stage later for sure. but it meets all the safety requirements.
don't worry too much about creepage distances because I take care of them really well with an additional 3mm airgap between primary and secondary, also were needed at some specific locations at the primary side.
Thanks!
