Wow!BIO: Millennia Media
In this test, we find that a $1.00 opamp with 0.001% THD sounds more pure and accurate and spatial, more true to the reference, than a $5.00 opamp with 0.0001% THD. We decide to ship the product with $1.00 opamp with poorer quantitative THD.
This statement holds no weight without knowing the final THD figures of the completed product(s) in which these opamps were tried.
I agree with this from my experience recording and listening to music. The idea that anybody would be able to hear a -120dB distortion tone whilst listening to a 0dB tone seems ridiculous to me. I have written here before that such performance may be needed for a device which can record all audible sound but has no volume/level control but I don't know of one, or see the need for such a device.In a conversation with Amir (long ago), he shared that "yes, there are multiple ways based on psychoacoustics that we can calculate the distortion-free channel we need for full transparency" and restated that -120dB THD is required for "full transparency."
No.
Are we being fair/slightly misleading (to the less technically aware) with the SINAD measurements? Thought I would get some feedback on this.
Below is the table we are compiling for SINAD performance. However we are comparing components that have disparate output voltages. The typical output voltage for dBFS is 2 V rms and seems to be a sort of unofficial standard, however some of the DACs here are producing anything up to 20 V rms. This will obviously bring an advantage to the measurement, but not necessarily in the case of usage. Whilst it is perfectly correct to measure the full voltage SINAD, should we also perform a nominal 2 V rms measurement for fairer comparison? Thoughts?
Example
Chord Mojo Fed with 0dBFS signal. Output volume set to 2 V RMS. SINAD = 100dB
Volume set just prior to clipping at 5 V rms. SINAD = 106.6dB
I remain unconvinced that every thing that matters has been measured, therefore, some headroom is desirable.
Yes. The idea of "possibly beneficial performance headroom" can be valid -- especially for specs like noise, linearity, jitter, and SR-related filter performance. If I had the choice of a DAC with 27-bit linearity over today's very best DACs with 21-bit linearity, I would take the 27-bit DAC (and hope that someday the rest of the audio industry caught up with 27-bit performance - mics, ADCs, DAWs, power amps, etc.).
The same argument doesn't hold for THD.
But, hey, if anyone believes there's a better than 50:50 chance that a 0.0001% DAC will sound more accurate than a 0.001% DAC, knock yourself out. We all know that faith and beliefs are often stronger than settled science.
Well, I remember as I have read each one of them 100 times. You must be talking about the few published limited tests like Clark's:Yes, it was an AES paper years ago, maybe more than one ABX study. JJ might remember.
I am afraid there is no such fact. I have performed countless controlled tests of devices with high distortion versus low. At best they sound the same. At worse, they sound worse. In no case have I found the distortion to have any value whatsoever.Can assure you, after 30 years of designing and blind AB listening to world-class audio circuits (over 50,000 channels in use at the highest levels of professional audio, film scoring, classical music, post production, archiving, etc.), THD below a certain threshold in no way correlates with better perceptual audio quality. None. In fact, in many cases, it's just the opposite (see my prior post).
Noted but the ranking is working in getting more and more manufacturers to find sources of noise and distortion and fixing them. Often it costs nothing but better circuit layout or implementation to get there. Maybe the distortion is audible, maybe it is not. But it is certainly a good thing to build cleaner performing audio products at no cost to consumers.I would encourage ASR to not "qualitatively rank" audio gear based on THD. Giving performance numbers is fine, but use care in making scientifically qualitative inferences that have no basis in science.
Some of the best performing op-amps (THD, slew, etc.) in fact are video op-amps, and yet some of them have a pinched, subtle granularity to their top-end and overall timbre. Over the decades, we've tested scores of commercial audio op-amps all with superb THD performance (TI, BB, NJR, AD, ST, Nat, etc.) and have never found a correlation between THD % and sonic transparency, purity, timbre neutrality, dynamic stability, and so forth.
That is not what I have said. What I have said is that I can guarantee transparency for all people, in all systems and all content if SINAD distortion products are at or below 116 dB (I sometimes round this up to 120).Some time ago, we had a conversation in which you said "-120dB THD is required for full transparency." I think you also directed me your "audibility threshold" page which said the same thing. If it's true that we cannot perceive THD artifacts below, say, 0.1% (-60dB), then we should probably have a further conversation on this "-120dB THD" postulate. But I guess the onus is on me to find the historical ABX tests on THD perception. I'm on it.
That is not what I have said. What I have said is that I can guarantee transparency for all people, in all systems and all content if SINAD distortion products are at or below 116 dB (I sometimes round this up to 120). Anything below becomes shades of gray.
Unfortunately many of these phrases are ill defined audiophile hubris."
Unless you mean something like frequency response being a factor, then the science absolutely supports what I said. I linked to peer reviewed journal papers including some from ex president of AES (Fielder). If they are not right, then you might as well throw out all the science.OK, we're missing an important element in the "transparency" conversation. Just because an audio device has low noise and low THD does not mean it sounds accurate or transparent. This is a non-scientific assumption. We cannot "guarantee perceptual timbre accuracy" just because THD is below X.XX%. Am I understanding your assumption correctly? If not, please help.
I thought you had done this for 30 years. If so, can you please post the protocols, what was tested, etc.I'm also starting to think of an AB test we could create, with the help of some old-timers here. We could create a simple test bed for A=1 amplifiers: an "A" amp, a "B" amp, and a direct path for original source -- of course all trimmed to better than 0.02dB offset. The selected amplifiers will exhibit a range of inherent THD, from 0.0001 range (audio IC) to 0.1 range (discrete). We use immediate switching. We ask experienced listeners to determine which amplifier sounds closer to the direct path. We do this for perhaps 10 representative amplifiers for a legitimate sample size.
Scott, help me out. If you ran a high-end audio company for 30 years and did AB listening comparisons on a regular basis for a living, and you shared some of your AB testing experience on-line, would that be hubris? (defined as "excessive pride or self-confidence"). Confused here.
