silver voice coil
steve59
I own a pair of speakers that add silver voice coil in the tweeter description and looking up speaker components this seems rather unusual and uncommon. anybody?
DonH56
Monument, CO
Aluminum voice coils are common, have not seen (but not looked for) silver. Seems like a very pricey option... I don't recall melting points but I think silver is better than copper, and has slightly less resistance so not a bad idea if you can afford it. I'd be worried they make the silver so small it increases resistance, however, to save costs. Copper and silver have lower resistance than aluminum but also lower melting points IIRC. Heat is an issue in a voice coil, but just one of many variables.
It could also be silver plated...
Can't imagine it impacts performance.
Grotti
Would you mind to tell us, which speakers you own?
Doodski
Silver melts @ 961.8C and aluminum @ 660.3C.
Silver weighs ~10,497 kg / m cubed and aluminum weighs ~2700 kg / m cubed.
Some advantages to both dependent on the properties required.
RayDunzl
Central Scrutinizer
Riverview FL
Melting Point
Aluminum: 660°C (1220°F)
Silver: 961°C (1762°F)
Copper: 1084°C (1983°F)
Aluminum probably used for lighter weight
Substance kg/m3 lbs/ft3
Aluminium 2,720 170
Copper 8,960 560
Silver 10,480 655
"Aluminum has 61 percent of the conductivity of copper, but has only 30 percent of the weight of copper."
steve59
steve59
Meridian dsp, I saw made in Norway on the magnet so Seas likely
egellings
Whew! I hope we never operate tweeters anywhere near that temperature range.
Doodski
Hehe... I provided warranty service for Energy and KEF for several years and some of the speakers that came in for service smelled so badly of burned ferrofluid and burned voice coils that we serviced them ASAP just to get rid of them. The KEF owners where a bit better with the gear but the Energy stuff was often abused big time. We where advised to replace the tweeters/woofers under warranty but on the 3rd time they would pay for their repetitive abusing the speakers. The customers received plentyyy of warning to stop blowing drivers or get bigger badder speakers.
DonH56
Monument, CO
Melting Point
Aluminium 2,720 170
Copper 8,960 560
Silver 10,480 655
Thank you! I was way off with the melting points, but at least I remembered weight and conductivity... Al is lighter and cheaper than copper (or silver, natch).
fpitas
Northern Virginia, USA
And since tweeters usually have a resistor in the crossover network...well...
steve59
steve59
so a silver vc could mean less material translates to lighter possibly faster? I count on you guys to read past the bs
MAB
Portland, OR, USA
Silver would require 3% less wire than copper for equivalent DCR. Or have 3% lower DCR for the same turns and wire diameters. I don't know what percentage of a driver's moving mas is the vc, but it seems tiny, and 3% of tiny is super tiny. Silver VC appears to have zero merit. I hope they don't charge a premium for the silver, there's very little of it in the VC and no way it is changing the sound!
fpitas
There's a reason it's unusual that they use silver. Unfortunately, I doubt it has any benefits other than for marketing.
RobL
No.
No good reason to use silver wire in a VC except maybe marketing. Copper has 96% of the conductivity of silver but only 85% of the mass. You can get a lighter VC with copper given the same resistance, conversely with the same mass coil, copper with give you more windings = greater flux.
