Copper and silver have lower resistance than aluminum but also lower melting points
Whew! I hope we never operate tweeters anywhere near that temperature range.Silver melts @ 961.8C and aluminum @ 660.3C.
Silver weighs ~10,497 kg / m cubed and aluminum weighs ~2700 kg / m cubed.
Some advantages to both dependent on the properties required.
Hehe... I provided warranty service for Energy and KEF for several years and some of the speakers that came in for service smelled so badly of burned ferrofluid and burned voice coils that we serviced them ASAP just to get rid of them. The KEF owners where a bit better with the gear but the Energy stuff was often abused big time. We where advised to replace the tweeters/woofers under warranty but on the 3rd time they would pay for their repetitive abusing the speakers. The customers received plentyyy of warning to stop blowing drivers or get bigger badder speakers.Whew! I hope we never operate tweeters anywhere near that temperature range.
Thank you! I was way off with the melting points, but at least I remembered weight and conductivity... Al is lighter and cheaper than copper (or silver, natch).Melting Point
Aluminum: 660°C (1220°F)
Silver: 961°C (1762°F)
Copper: 1084°C (1983°F)
Aluminum probably used for lighter weight
Substance kg/m3 lbs/ft3
Aluminium 2,720 170
Copper 8,960 560
Silver 10,480 655
"Aluminum has 61 percent of the conductivity of copper, but has only 30 percent of the weight of copper."
Conductivity only matters when both wires have exactly the same diameter and length.Slightly better conductivity. Not enough to make a difference in the tweeter's performance.
???...Conductivity only matters when both wires have exactly the same diameter and length.
Conductivity of the metal is what determines the end-to-end resistance of a given wire.???...
Silver would require 3% less wire than copper for equivalent DCR. Or have 3% lower DCR for the same turns and wire diameters. I don't know what percentage of a driver's moving mas is the vc, but it seems tiny, and 3% of tiny is super tiny. Silver VC appears to have zero merit. I hope they don't charge a premium for the silver, there's very little of it in the VC and no way it is changing the sound!so a silver vc could mean less material translates to lighter possibly faster? I count on you guys to read past the bs
No.so a silver vc could mean less material translates to lighter possibly faster? I count on you guys to read past the bs
