Vini darko
This thread
Hi,
Disingenuous ? Isn't that a diplomatic way to tell me you think I am stupid ?
And your argument is to say "You're wrong because you don't think like I do". At lest this is what I read...
I don't force anyone in here to hear a difference when they're convinced there aren't (or can't be).
I am only stating that, as far as I am concerned, I am convinced that, when I listen to music with different devices, I can "feel" the difference.
I expect science to tell me why that happens.
Not that I am wrong.
If the explanation is "That is psychology", I am OK with that.
After all psychology is a science too, is it not ?
And I will stop replying here.
It's just a waste of time.
Unfortunately, I haven't that much spare time to waste :-(
I'll simply continue to live in my world of biased beliefs.
After all, my quest is just for pleasure.
If a device gives me that, then I am happy with it...
Despite what all measurements can tell, it is perfect TO ME.
If your pleasure is to have the device that has the best measures, fine.
If that device gives you satisfaction when you listen to music, it is perfect FOR YOU.
And if you like it, I do respect that even if I disagree (which is not always the case).
Best regards.
Dvořák is usually happier than Beethoven.Really ?
Do you think I am that stupid ?
YES :
I listened to Dvorak's 9th by Leopold Ludwig using DAC A, headphone amp A and headphones A.
Then I listened to Beethoven's 9th by Karajan and used DAC B, headphone amp B and heaphones B.
And guess what : I found out that there was a difference !
My conclusion is simple : Dvorak is not Beethoven. Beethoven is not Dvorak...
Seriously ?
After all psychology is a science too, is it not?
No. I don't think you are stupid. You clearly seem disingenuous. Might want to look up what that word means.
You made some statements with faulty assumptions about the objective point of view
https://www.audiosciencereview.com/...s-a-sound-signature.9245/page-102#post-586909
I replied, in good faith, with explanations of why some of those statements are faulty
https://www.audiosciencereview.com/...s-a-sound-signature.9245/page-102#post-586923
Rather than engaging with what I said, you have continued to rant and make further statements based on faulty assumptions.
"Definition of disingenuous: lacking in candor also : giving a false appearance of simple frankness: CALCULATING"
Yes, that seems to be what you read.
And science has told you. So have we. It is called "expectation bias".
Are you?
Mostly, yes.
Still, no comment.
There are clear scientific explanations that explain subjective results. The science of cognitive psychology.Rather than simply denying that subjective methods might produce valid results, the true scientists among the objectivist throne ought to be looking at scientific explanations for subjective results.
For what it's worth I bought a Topping DX7s DAC+headphone amp based on ASR recommendation. That resulted in my selling my 3x more expensive DAC for much more than I paid for the Topping, and keeping the latter.To answer the thread question 102 pages ago... You sell them a $35,000 DAC.
There a smug answers for a lot of things.There are clear scientific explanations that explain subjective results. The science of cognitive psychology.
Still, the "no comment" comment.
I am still not a reporter.
That is the explanation. What you perceive can be explained by cognitive psychology rather than by the qualities inherent in a DAC.If the explanation is "That is psychology", I am OK with that.
I'm not a cognitive psychologist but do have an awareness of the impact of the discipline and how it might be applicable to situations/practices/discourses etc.. Otherwise why would I have mentioned it?Hi,
Anyone a cognitive psychologist in here ?
Sorry, is that an answer? I have replied to your post with an honest answer. The science of cognitive psychology helps to explain subjective responses in many areas and walks of life. What on earth is smug about that? Are you wanting to engage or not?There a smug answers for a lot of things.
Yes, sure, cognitive psychology explains a lot. There are audiophiles who firmly believe that 'Brilliant Pebbles' make for better sound; (see ... https://www.machinadynamica.com/machina31.htm). I believe that cognitive psychology explains why some people do.Sorry, is that an answer? I have replied to your post with an honest answer. The science of cognitive psychology helps to explain subjective responses in many areas and walks of life. What on earth is smug about that? Are you wanting to engage or not?
Your perception is not false, it's just that it has nothing to do with the DAC (unless the DAC is badly engineered, broken etc.).
How can something that can't have sound signature be given a sound signature if it is badly engineered ?
That's correct, as long as the DAC is transparent (see below).There is a statement that a DAC can have no sound signature.
Is that correct ?
It will have a sound signature if it's badly engineered. (This might be a deliberate "feature".) This will be due to colouration/distortion or whatever word you choose. The key thing here is that this sound signature will show up in a DAC's measurements.And then I am told "Unless it is not well engineered".
This is what I do not understand.
Is that correct ?
