We're talking about an SET, so yes, bandwidth is a problem. I suspect the Lamm likely didn't have power bandwidth much past 20KHz.
The HF side of SET is generally not a problem. Winding transformers with enough sections to have ~ 100kHz -3dB is not in itself difficult.
Tango and Tamura did it for decades, I designed a few like that being far from a transformer specialist (I remember absolutely hating the nearly half year in my EE course where we dealt with magnetics).
You misinterpreted my comment. What you say above is true; as you know the deadtime remains the same regardless of frequency for any given set of devices.
So, change the devices? After all we are designers here. GAN is quite interesting.
We are only limited if we don't do our homework and instead act like Chinese and buy in (or illegally copy) other peoples work.
So while you get greater loop gain, you need it to deal with the increased distortion.
No, you need to look at this on a system level.
For example, using different drivers can reduce dead time using the same devices. Just evacuate the gate charge faster.
How? How about a positive feedback loop creating negative impedance as long as there is gate charge to evacuate or charge.
Use your imagination.
That is why you don't see super high switching frequencies in most modern class D amps.
And that is why they are wrong. They are lagging behind DC-DC conversion tech by decades, for no good reason.
I can't speak for all amps in this regard but as you might have surmised, quite a lot of work has to go into a self-oscillating design to insure that it handles clipping correctly.
Clipping is another subject.
If we design "25W music" tube Amp's, clipping behavior is paramount, as we will face clipping on peaks, which will be inaudible as long as it is instant and turns off instantly.
Any stickage on the rail(s) or material operating point shift is a problem.
With a "500W" amp we have more headroom, clipping should normally not happen, so we can relax requirements.
A lot of the patent work of the Purifi module is about this very issue. The result is the clipping character is like that of any conventional solid state amp.
Since most solid state amps and most class D amps have a fairly abrupt clipping onset, the solution of course is to simply make sure you have enough power.
Or incorporate soft clipping? I remember using tape saturation as "limiter" during recording in the 80's. Sounds swell. Beats any other limiter I tried.
Oh, oops, the result does not measure "happy panther", mind you, the Panthers don't listen, as they are ceramic.
Past that, I have been following Brüno's path with interest. He reminds me that that there is always an alternative to precision directed fire that takes the head of the enemy and thus secures a win with minimal casualties for both sides. Unlike the RuSSian equivalent of the good old banzai charge.
Why solve the root cause of a problem, when you can add more feedback? Why, more feedbacks makes clipping recovery difficult, so let's introduce non-linear "edge of clipping" limiting elements and use more feedback. What, your output inductor adds distortion? Add even more feedback.
I usually look at what Brüno does to give me a shortcut to know where else to look.
I believe in solving problems by resolving the root cause.
Thor
