StefanSweden
- Joined
- Apr 26, 2023
- Messages
- 130
- Likes
- 129
Hi everyone,
I recently asked questions in another thread but felt it would be better to start my own, so that's what I'm doing now.
I’ve always enjoyed good sound but never enough to dive deep into the technical aspects of HiFi. The more I read, the more I learn—but I’m also finding myself stuck in a cycle of “paralysis by analysis.” It’s consuming a lot of time that I’d rather spend on my job and family.
With this thread, I’m hoping to tap into the experience of those who’ve already walked this path and get some guidance on building a “good enough” system. My goal is to find a setup, buy it, and then leave all the forums, YouTube channels, and Reddit threads behind—just to focus on enjoying music and living my life.
My current modest setup (Dali Oberon 1, SVS SB-1000 Pro, Bluesound Powernode Edge) will be used in a smaller space upstairs. For the living room, I’d like to build a new HiFi system.
I’m torn between standmount and floorstanding speakers:
I’d greatly appreciate recommendations or thoughts on the setup I’m considering. Keep in mind my technical expertise is limited, and I want a setup that allows me to focus on the music and not the gear. I hope this is the last system I buy or at least for 20-30 years.
Thank you!
The Context:
We’ve recently moved into a house with a living room of about 430 sq ft (40 m²) in an open-plan layout. One side of the room is covered with windows, and it’s a typical living room with furniture (no acoustic treatments like panels or diffusers). Speakers will have to be placed close to the wall behind them, as there’s no space to bring them further into the room.My current modest setup (Dali Oberon 1, SVS SB-1000 Pro, Bluesound Powernode Edge) will be used in a smaller space upstairs. For the living room, I’d like to build a new HiFi system.
- Budget: $3,000–$4,000
- Usage: Streaming only
- Listening Habits: I listen at moderate volumes (~60dB) most of the time but love cranking it up to ~100dB occasionally.
- Future Additions: Planning to add a subwoofer later, and this is very important for me. The system should allow easy subwoofer integration with proper bass management and crossovers.
- Requirements:
- Power amp + streamer (I’d prefer to separate these for flexibility).
- Room correction and subwoofer integration (Dirac or similar).
- Must have an app for easy use, as my wife will also use the system.
Speaker Choice:
I’m allocating ~$3,000 for speakers. I’ve been auditioning various options at HiFi stores to understand what sound signature I prefer. I mainly listen to rock music but enjoy a wide range of genres.I’m torn between standmount and floorstanding speakers:
- Floorstanding speakers: Likely better for hitting ~100dB without strain.
- Standmount speakers: May pair well with a sub in the future but might struggle with higher volumes.
Constraints:
The system must be simple enough for the whole family to use, capable of high volumes, and work in a living room without acoustic treatments (no panels, diffusers, etc.). Also, as I mentioned earlier, my technical knowledge is limited, so I’d appreciate it if recommendations and discussions could keep that in mind and align with my perspective.I’d greatly appreciate recommendations or thoughts on the setup I’m considering. Keep in mind my technical expertise is limited, and I want a setup that allows me to focus on the music and not the gear. I hope this is the last system I buy or at least for 20-30 years.
Thank you!
