StefanSweden
- Joined
- Apr 26, 2023
- Messages
- 130
- Likes
- 129
- Thread Starter
- #61
The speakers will go on stands for sure. The livingroom will be quite crowded from furniture and I think a tower speaker will look cramped. A stand mount will certainly look a bit more sleek (maybe not SourcePoint 8Both solutions can be good if you choose good speakers but what I'm wondering is if you're going to have the bookshelf speakers on a stand? If so, they will take up about the same kind of physical space as a pair of floor standing speakers. IF that is the case, what do you gain from it? Other than that you can get a stand that gives the possibility of customized placement height of the speakers.
If you are going to place the speakers on stands and want them in metal, I can recommend you contact a local welding shop. They can create some custom ones for you.![]()
Read some where that, say, a 2000$ stand mount will get you a better speaker than a 2000$ tower?
I need to get out and listen to speakers more to get a feel for different manufacturers house sound.
There is a Dynaudio Evoke 30 on sale at hifitorget.se for 25.000sek (~2200$) which I have not yet heard, but it looks great and the price could be right.
