Depends on your system. You will need a decent set up to benefit much.Almost certainly. But you could also look at the cheaper Mani 2.
Fair enoughDepends on your system. You will need a decent set up to benefit much.
Lower added noise. I’m not clear exactly how much difference it makes for “quality” in spending more for one SUT versus another. The SNR for a preamp like the one reviewed may make it a more affordable gain option than a SUT plus a good MM phonostage.I am considering a step up transformer, one of the $200 cheapos on the bay maybe. What's the advantage over just the preamp?
So I have a dumb question.. since phono cartridges are balanced… but RCA is SE.. what exactly happens if I where to go from RCA out into the skoll and from there with XLR into a amplifier?
Not sure if this preamp would be a upgrade to the internal one in my Technics SL1500C ?
I have a question if you don't mind? Did you try shorting plugs on the input of the RCA connector on your Skoll? This will tell you if the problem is the Skoll or before it. Most of the time it's something else before the phono preamps.Hello,
I have the Skoll, and I sent my original back for replacement as the left channel had a "buzzing" type noise that was clearly audible when you put your ear up to the midrange and tweeter. This did not present itself on the right channel. The replacment Schiit sent was better, but the same problem. I have 2 other phono stages on hand, a MoFI Studio and a Rega Fono, neither of these have the noise in the same system, using the same equipment.
I've also swapped cables, check the same RCA inputs using other gear, tried plugging in to different outlets etc.... When I swap the L and R RCA's coming out of the Skoll into my preamp (Schiit Kara) the noise switches sides. Again, this is only with my ear up by the speaker, less than a foot.
I guess my question is, did you hear anything like this when you tested? I'm baffled, and I seem to have isolated this to the Skoll, both units I've had.
Any input welcomed!
Thanks,
Chris Rud
I had this same problem. Sent the second Skoll back and got a refund. When trouble shooting, I swapped the left/right RCA's coming into the Skoll. The buzz remained in the left channel.I have a question if you don't mind? Did you try shorting plugs on the input of the RCA connector on your Skoll? This will tell you if the problem is the Skoll or before it. Most of the time it's something else before the phono preamps.
When I switched the RCA's of the output, the buzz moved to the right. I concluded that the sound was indeed coming from Skoll.
Seems for some, it's barely noticeable. It was definitely too noticeable to ignore in both units I tried. I haven't heard anything regarding a solution or fix.News if this was Just bad luck or did shiit fix this issue? I’m really interested in the Skoll as upgrade sometimes next year but a Buzz in one channel is something I definitely don’t want.
I don't think they should be waiting for V2 to fix anything. I've seen this discussed on other forums and in youtube comments on reviews of this unit. Maybe its all the same people, but? I had a friend pick one up recently and I intend on test measuring both the balanced and unbalanced inputs and outputs for all the gain settings.I can't hear the buzz at my listening position at normal listening volume, only if I put my ear up to the speaker I can. If I turn up the volume to reference level I can hear the buzz at listening position which is a bit annoying since I like to do that when the wife leaves the house, but once the music starts it's not noticeable. It's one HELL of a great sounding phono pre amp at it's price point and you'll have to pry it out of my cold dead hands even with the small, although annoying flaw. Hopefully they can work out the kinks in Skoll v2 when that comes out in a year or 2.
I noticed that too, but my replacement was shipped within a couple days.I also got one around the same time, so far so good, no issue at all. Super quiet and revealing in a pleasant way. Just another data point.
Noticed that the shipping time now is 2-3 weeks. Maybe a sign of some issue being dealt with?
MC cartridges don’t always sound better, but because they tend to have lower moving mass, they can be better at detail retrieval and high frequency response.That's an excellent question and one that I have asked many times over the years. I have only once owned a MC cartridge, a low output Denon DL-304, that while quite good, it failed to truly impress and reignite my passion for LP reproduction...
