Schiit Freya S Preamplifier Review
stereo coffee
Dude. Duuuuuude. Listening tests are, by and large, unproductive and usually misleading. If you have 82 messages here, you should know that by now.
We will have to agree to disagree. If we view listening tests as unproductive and usually misleading, evaluation of equipment is then quite alien to our actual capability to discern and make choice, which includes enjoyment.
Dwelling in a world of measurements and visual treats alone, Yes is informative to a degree and looks very impressive, but should always be, IMO secondary to actual listening experience.
LTig
Europe
They can as well. The resistors have to have very low voltage coefficient to have no measurable distortion with apx555.
IMV this is more a problem with higher voltages, not really relevant at line level. The resistors in the attenuator must be of similar quality as all other resistors in the signal path, of course.
March Audio
Albany Western Australia
That wouldn't be the same volume on each preamp. I am asking what target gain we should test at.
So we test power amps at 5 watts into 4 Ohms which is 4.45 volts rms output. 26dB is a typical power amp gain so input needs to be 223mV rms to acheive this level.
I think SINAD at this level would be more informative.
Also what input level to the pre amp? I would suggest typical DAC output of 2 volts rms
JohnYang1997
China
Nope. I expect less distortion, but also less SNR.
I have measured various resistors with relays with apx555. Voltage coefficient is very important. The harmonics is less than the accumulated noise but it will rise when attenuated even -1db.
LTig
Europe
How do we set the generator and the volume to get 223 mV rms output level?
  • For low gain mode I propose 2V rms input level (typical DAC output) and volume set accordingly
  • For high gain mode I propose either
    • 150 mV rms input level, or
    • use the same volume position as in low gain mode and adjust the generator accordingly.
March Audio
5 watt SINAD would be peak value then. I don't know why anyone would buy your power amp for peak power of 5 watts. :) That could one data point. But I think it is too low of a target.
Sure, it's only a "typical listening" data point. As for power amps we want to see the max output too.
March Audio
Sorry I updated my post as you were replying. :)
Blake Klondike
Are there better recommendations out there for the same/less dough? I have always been baffled by what seem like high prices from all companies for what is basically a channel switcher and volume control for active speakers. Is there other valuable functionality here that I am missing? Would really like a transparent way to run a T/T and DAC into a pair of Genelecs but it seems like choices are $39 on-line junk or fairly expensive units.
majingotan
Laguna, Philippines
Schiit Magni Heresy or JDS Atom or MacKie Big Knob 2x2 passive preamp
Blake Klondike
I have been haunting all the hifi stores in New England for a couple years trying to solve the pre-amp problem, and the unspoken industry consensus seems to be "$2000 is cheap-- if you don't want to spend at least that, come back when you inherit some money".
LTig
Europe
Interesting - can you show a graph and which type of resistors you've measured? I know only the results of Douglas Self's measurements in his book Small SIgnal Audio Design.
Of course. At full volume the attenuator does not attenuate, the signal just passes a relay and not a resistor.
March Audio
It's something I'm frequently asked about by customers but simply can't give an answer because we just don't have the data.
A call out to to ASR readers to send in their pre amps :)
Reactions: jjk
majingotan
Laguna, Philippines
Thanks for the recommendations. These don't appear to have multiple ins though?
Nope Except for Mackie Big Knob 2x2 with 2 inputs and 2 outputs and can be either TS or TRS balanced
JohnYang1997
China
His measurements are over ppm. Apx555 here has distortion harmonics of near -150db which is 30db less than ppm. Any precision analogue designer knows that sub ppm is a completely different world.
Even then, Douglas self has stated in the amplifier design book that feedback resistors of the amplifier are extremely important because of the voltage coefficient. Any voltage division will have voltage coefficient in the equation. Just let amir measure -3db or so attenuation and see how the harmonic goes. I predict it will increase to around -130db or even -120db instead of the -150db mark without any attenuation.
direstraitsfan98
Akitika PR-101 as a kit is $379 plus shipping. I replaced my Pass Labs XP-10 with it, which at $5,250 was over 10 times the price. I can't say that the Akitika pre sounds 'better' since I did not ABX test the two but I'd say it doesn't sound worse at the very least. It also has far more features then you get with a typical esoteric linestage.
LTig
Europe
For 6 high level sources the LAP-2 by Funk Tonstudiotechnik is a very good product, but not really cheap (starting at ~ € 1100). It measures almost perfectly.
