- Joined
- Jan 5, 2023
- Messages
- 100
- Likes
- 48
Are there any modern/contemporary units available that one can buy new, rather than scouting for an outdated (by the market) unit...
many thanks
-vin
many thanks
-vin
Ultra HD Blu-ray, BD-ROM, Stereoscopic 3D (profile 5), SA-CD (SA-CD/CD) Playback, DVD-Video, DVD-Audio, DVD-R, DVD-RW, DVD-R Dual Layer, DVD+R, DVD+RW, DVD+R Double Layer, CD (CD-DA), CD-R/-RW
Not sure you can rip SACD’s with this model.
An SACD player with digital output will pass the CD layer on a multi-format SACD but not the SACD layer.I didn’t think it was possible to digitally rip an SACD from any SACD player because the format did not permit a digital output on the player , only an analogue output.
Yes, that’s it. The point I was trying to highlight was if you’re ripping an SACD hoping you’ll be ripping the enhanced information from the SACD layer of course you won’t be. As you say, it will be CD layer.An SACD player with digital output will pass the CD layer on a multi-format SACD but not the SACD layer.
Yes, sorry I missed your original post as I repeated what you had already shared with usYes, that’s it. The point I was trying to highlight was if you’re ripping an SACD hoping you’ll be ripping the enhanced information from the SACD layer of course you won’t be. As you say, it will be CD layer.
Obviously incorrect but stated with confidence!Yes, that’s it. The point I was trying to highlight was if you’re ripping an SACD hoping you’ll be ripping the enhanced information from the SACD layer of course you won’t be. As you say, it will be CD layer.
Why is his statement incorrect? Yes, you can rip the SACD layer using the USB stick method on certain Sony players (and my OPPO 103 if I go to the trouble) but it's a PITA to get it all setup. There is no way I know of to rip directly from the player without using the kludge.Obviously incorrect but stated with confidence!
If you actually try it, you may find that it is quite easy and gets easier with practice. With my setup, I can unwrap an SACD and have it being ripped in less than 2 minutes. As they say, "Don't knock it until you try it."Why is his statement incorrect? Yes, you can rip the SACD layer using the USB stick method on certain Sony players (and my OPPO 103 if I go to the trouble) but it's a PITA to get it all setup. There is no way I know of to rip directly from the player without using the kludge.
Edit: ok, the above linked thread makes it a bit easier, but still extra steps. Thanks for sharing that.
How very charmless of you! I got it wrong in my previous post and in this post I was just confirming the correction that r042wal made. How you can glean any measure of confidence from my post I’ve no idea.Obviously incorrect but stated with confidence!
How can you rip in 2 minutes? Mine takes like 30 minutes.If you actually try it, you may find that it is quite easy and gets easier with practice. With my setup, I can unwrap an SACD and have it being ripped in less than 2 minutes. As they say, "Don't knock it until you try it."
+1 In the past I have messed around with trying to rip SACD's with the PS3 and gave up. Then recently I tried again with the latest USB drive method with the older player and it is easy, fast, and reliable and it puts a smile on my face every time thinking about how creative people are to come up with a hack like this. There is never going to be a new approved device to rip SACD's but this works so well it doesn't matter. If you have SACD's to rip don't hesitate to pick up an old player and use the USB method.If you actually try it, you may find that it is quite easy and gets easier with practice. With my setup, I can unwrap an SACD and have it being ripped in less than 2 minutes. As they say, "Don't knock it until you try it."
